Asterisk 1.6.2.10, Copyright (C) 1999 - 2010 Digium, Inc. and others.
Connected to Asterisk 1.6.2.10 currently running on ippbxvg (pid = 2794)
Verbosity is at least 3
== Using SIP RTP TOS bits 184
== Using SIP RTP CoS mark 5
-- Executing [1102@from-internal:1] Macro("SIP/1207-00000047", "exten-vm,novm,1102") in new stack
-- Executing [s@macro-exten-vm:1] Macro("SIP/1207-00000047", "user-callerid,") in new stack
-- Executing [s@macro-user-callerid:1] Set("SIP/1207-00000047", "AMPUSER=1207") in new stack
-- Executing [s@macro-user-callerid:2] GotoIf("SIP/1207-00000047", "0?report") in new stack
-- Executing [s@macro-user-callerid:3] ExecIf("SIP/1207-00000047", "1?Set(REALCALLERIDNUM=1207)") in new stack
-- Executing [s@macro-user-callerid:4] Set("SIP/1207-00000047", "AMPUSER=1207") in new stack
-- Executing [s@macro-user-callerid:5] Set("SIP/1207-00000047", "AMPUSERCIDNAME=test2") in new stack
-- Executing [s@macro-user-callerid:6] GotoIf("SIP/1207-00000047", "0?report") in new stack
-- Executing [s@macro-user-callerid:7] Set("SIP/1207-00000047", "AMPUSERCID=1207") in new stack
-- Executing [s@macro-user-callerid:8] Set("SIP/1207-00000047", "CALLERID(all)="test2" <1207>") in new stack
-- Executing [s@macro-user-callerid:9] ExecIf("SIP/1207-00000047", "0?Set(CHANNEL(language)=)") in new stack
-- Executing [s@macro-user-callerid:10] GotoIf("SIP/1207-00000047", "0?continue") in new stack
-- Executing [s@macro-user-callerid:11] Set("SIP/1207-00000047", "__TTL=64") in new stack
-- Executing [s@macro-user-callerid:12] GotoIf("SIP/1207-00000047", "1?continue") in new stack
-- Executing [s@macro-user-callerid:19] NoOp("SIP/1207-00000047", "Using CallerID "test2" <1207>") in new stack
-- Executing [s@macro-exten-vm:2] Set("SIP/1207-00000047", "RingGroupMethod=none") in new stack
-- Executing [s@macro-exten-vm:3] Set("SIP/1207-00000047", "VMBOX=novm") in new stack
-- Executing [s@macro-exten-vm:4] Set("SIP/1207-00000047", "EXTTOCALL=1102") in new stack
-- Executing [s@macro-exten-vm:5] Set("SIP/1207-00000047", "CFUEXT=") in new stack
-- Executing [s@macro-exten-vm:6] Set("SIP/1207-00000047", "CFBEXT=") in new stack
-- Executing [s@macro-exten-vm:7] Set("SIP/1207-00000047", "RT=""") in new stack
-- Executing [s@macro-exten-vm:8] Macro("SIP/1207-00000047", "record-enable,1102,IN") in new stack
-- Executing [s@macro-record-enable:1] GotoIf("SIP/1207-00000047", "1?check") in new stack
-- Executing [s@macro-record-enable:4] ExecIf("SIP/1207-00000047", "0?MacroExit()") in new stack
-- Executing [s@macro-record-enable:5] GotoIf("SIP/1207-00000047", "0?Group:OUT") in new stack
-- Executing [s@macro-record-enable:15] GotoIf("SIP/1207-00000047", "1?IN") in new stack
-- Executing [s@macro-record-enable:20] ExecIf("SIP/1207-00000047", "0?MacroExit()") in new stack
-- Executing [s@macro-record-enable:21] NoOp("SIP/1207-00000047", "Recording enable for 1102") in new stack
-- Executing [s@macro-record-enable:22] Set("SIP/1207-00000047", "CALLFILENAME=20101220-175621-1292842581.71") in new stack
-- Executing [s@macro-record-enable:23] MixMonitor("SIP/1207-00000047", "20101220-175621-1292842581.71.wav,,") in new stack
-- Executing [s@macro-record-enable:24] Set("SIP/1207-00000047", "CDR(userfield)=audio:20101220-175621-1292842581.71.wav") in new stack
-- Executing [s@macro-record-enable:25] MacroExit("SIP/1207-00000047", "") in new stack
-- Executing [s@macro-exten-vm:9] Macro("SIP/1207-00000047", "dial,,tr,1102") in new stack
-- Executing [s@macro-dial:1] GotoIf("SIP/1207-00000047", "1?dial") in new stack
-- Goto (macro-dial,s,3)
-- Executing [s@macro-dial:3] AGI("SIP/1207-00000047", "dialparties.agi") in new stack
== Begin MixMonitor Recording SIP/1207-00000047
dialparties.agi: Caller ID name is 'test2' number is '1207'
dialparties.agi: Methodology of ring is 'none'
-- dialparties.agi: Added extension 1102 to extension map
-- dialparties.agi: Extension 1102 cf is disabled
-- dialparties.agi: Extension 1102 do not disturb is disabled
dialparties.agi: EXTENSION_STATE: 0 (NOT_INUSE)
dialparties.agi: Extension 1102 has ExtensionState: 0
-- dialparties.agi: Checking CW and CFB status for extension 1102
-- dialparties.agi: dbset CALLTRACE/1102 to 1207
-- dialparties.agi: Filtered ARG3: 1102
-- <SIP/1207-00000047>AGI Script dialparties.agi completed, returning 0
-- Executing [s@macro-dial:7] Dial("SIP/1207-00000047", "SIP/1102,,tr") in new stack
-- Called 1102
-- SIP/1102-00000048 is ringing
== Spawn extension (macro-dial, s, 7) exited non-zero on 'SIP/1207-00000047' in macro 'dial'
== Spawn extension (macro-exten-vm, s, 9) exited non-zero on 'SIP/1207-00000047' in macro 'exten-vm'
== Spawn extension (from-internal, 1102, 1) exited non-zero on 'SIP/1207-00000047'
-- Executing [h@from-internal:1] Macro("SIP/1207-00000047", "hangupcall") in new stack
-- Executing [s@macro-hangupcall:1] GotoIf("SIP/1207-00000047", "1?noautomon") in new stack
-- Executing [s@macro-hangupcall:3] NoOp("SIP/1207-00000047", "TOUCH_MONITOR_OUTPUT=") in new stack
-- Executing [s@macro-hangupcall:4] GotoIf("SIP/1207-00000047", "1?skiprg") in new stack
-- Executing [s@macro-hangupcall:7] GotoIf("SIP/1207-00000047", "1?skipblkvm") in new stack
-- Executing [s@macro-hangupcall:10] GotoIf("SIP/1207-00000047", "1?theend") in new stack
-- Executing [s@macro-hangupcall:12] Hangup("SIP/1207-00000047", "") in new stack
== Spawn extension (macro-hangupcall, s, 12) exited non-zero on 'SIP/1207-00000047' in macro 'hangupcall'
== Spawn extension (from-internal, h, 1) exited non-zero on 'SIP/1207-00000047'
== End MixMonitor Recording SIP/1207-00000047
ippbxvg*CLI>
Disconnected from Asterisk server
[root@ippbxvg ~]#
ippbxvg*CLI> sip show peer 1208
* Name : 1208
Secret : <Set>
MD5Secret : <Not set>
Remote Secret: <Not set>
Context : from-internal
Subscr.Cont. : <Not set>
Language :
AMA flags : Unknown
Transfer mode: open
CallingPres : Presentation Allowed, Not Screened
Callgroup :
Pickupgroup : 6
Mailbox : 1208@default
VM Extension : *97
LastMsgsSent : 32767/65535
Call limit : 50
Dynamic : Yes
Callerid : "device" <1208>
MaxCallBR : 384 kbps
Expire : -1
Insecure : no
Nat : Always
ACL : Yes
T.38 support : No
T.38 EC mode : Unknown
T.38 MaxDtgrm: -1
DirectMedia : No
PromiscRedir : No
User=Phone : No
Video Support: No
Text Support : No
Ign SDP ver : No
Trust RPID : No
Send RPID : No
Subscriptions: Yes
Overlap dial : Yes
DTMFmode : rfc2833
Timer T1 : 500
Timer B : 32000
ToHost :
Addr->IP : (Unspecified) Port 0
Defaddr->IP : 0.0.0.0 Port 5060
Prim.Transp. : UDP
Allowed.Trsp : UDP
Def. Username: 1208
SIP Options : (none)
Codecs : 0xe (gsm|ulaw|alaw)
Codec Order : (ulaw:20,alaw:20,gsm:20)
Auto-Framing : No
100 on REG : No
Status : UNKNOWN
Useragent : X-Lite release 1002tx stamp 29712
Reg. Contact : sip:1208@192.168.5.16:38938;rinstance=22c997cfcb013a4b
Qualify Freq : 60000 ms
Sess-Timers : Accept
Sess-Refresh : uas
Sess-Expires : 1800 secs
Min-Sess : 90 secs
Parkinglot :
ippbxvg*CLI> sip show peer 1102
* Name : 1102
Secret : <Set>
Language :
AMA flags : Unknown
Transfer mode: open
Callgroup :
Pickupgroup : 6
Mailbox : 1102@device
VM Extension : *97
Call limit : 50
Dynamic : Yes
Callerid : "device" <1102>
Expire : -1
Insecure : no
Nat : Always
ACL : Yes
T.38 support : No
T.38 MaxDtgrm: -1
DirectMedia : No
PromiscRedir : No
User=Phone : No
Video Support: No
Text Support : No
Ign SDP ver : No
Trust RPID : No
Send RPID : No
Subscriptions: Yes
Overlap dial : Yes
DTMFmode : rfc2833
Timer T1 : 500
Timer B : 32000
ToHost :
Prim.Transp. : UDP
Allowed.Trsp : UDP
Def. Username: 1102
Auto-Framing : No
100 on REG : No
Status : UNKNOWN
Reg. Contact : sip:1102@192.168.5.62:61652;rinstance=78f47fefdea87447
Sess-Refresh : uas
Min-Sess : 90 secs
Parkinglot :
ippbxvg*CLI> sip show peer 1207
* Name : 1207
Secret : <Set>
Language :
AMA flags : Unknown
Transfer mode: open
Callgroup :
Pickupgroup : 6
Mailbox : 1207@device
VM Extension : *97
Call limit : 50
Dynamic : Yes
Callerid : "device" <1207>
Expire : -1
Insecure : no
Nat : Always
ACL : Yes
T.38 support : No
T.38 MaxDtgrm: -1
DirectMedia : No
PromiscRedir : No
User=Phone : No
Video Support: No
Text Support : No
Ign SDP ver : No
Trust RPID : No
Send RPID : No
Subscriptions: Yes
Overlap dial : Yes
DTMFmode : rfc2833
Timer T1 : 500
Timer B : 32000
ToHost :
Prim.Transp. : UDP
Allowed.Trsp : UDP
Def. Username: 1207
Auto-Framing : No
100 on REG : No
Status : UNKNOWN
Reg. Contact : sip:1207@192.168.5.77:7718;rinstance=8f4cf3f2042a6325
Sess-Refresh : uas
Min-Sess : 90 secs
Parkinglot :
No such command 'sip show features
; Do NOT edit this file as it is auto-generated by FreePBX. All modifications to ;
; this file must be done via the web gui. There are alternative files to make ;
; custom modifications, details at: http://freepbx.org/configuration_files ;
; This file is part of FreePBX.
; FreePBX is free software: you can redistribute it and/or modify
; it under the terms of the GNU General Public License as published by
; the Free Software Foundation, either version 2 of the License, or
; (at your option) any later version.
; FreePBX is distributed in the hope that it will be useful,
; but WITHOUT ANY WARRANTY; without even the implied warranty of
; MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
; GNU General Public License for more details.
; You should have received a copy of the GNU General Public License
; along with FreePBX. If not, see <http://www.gnu.org/licenses/>.
; Copyright (C) 2004 Coalescent Systems Inc (Canada)
; Copyright (C) 2006 Why Pay More 4 Less Pty Ltd (Australia)
; Copyright (C) 2007 Astrogen LLC (USA)
featuredigittimeout = 5000
#include features_general_additional.conf
#include features_general_custom.conf
[applicationmap]
#include features_applicationmap_additional.conf
#include features_applicationmap_custom.conf
[featuremap]
#include features_featuremap_additional.conf
#include features_featuremap_custom.conf
sip*CLI> show features
Builtin Feature Default Current
Pickup *8 *8
Blind Transfer # ##
Attended Transfer *2
One Touch Monitor *1
Disconnect Call * **
Park Call
Dynamic Feature Default Current
(none)
Call parking
Parking extension : 700
Parking context : parkedcalls
Parked call extensions: 701-750ย้อนกลับไปยัง Elastix - Unified Communications Software
