โดย voip4share » 20 ธ.ค. 2009 13:27
13.2 Commands (Reference)
This section lists all commands that you can issue to the status port (manually or with an external application). Commands are not case-insensitive, but parameters may be.
Entering help or h will display a list of all available commands.
Reload
Reload the configuration.
Reloading the configuration will not terminate existing calls, and any change to settings will only take effect on new calls.
You can add an optional parameter to reload only a part of your configuration:
AcctConfig - reload only the accounting config
AuthConfig - reload only the authentication config
CapConfig - reload only the CapacityControl rules
EpConfig - reload only the endpoint config (permanent endpoints, endpoint section, call table settings)
Example:
Reload
Full Config reloaded.
Reload EpConfig
EP Config reloaded.
Shutdown
Terminate the gatekeeper. Can be disabled by Shutdown=forbid in section [GkStatus::Auth].
Version, v
Show the version and OS information of the gatekeeper.
Statistics, s
Show the statistics information of the gatekeeper.
Example:
Statistics
-- Endpoint Statistics --
Total Endpoints: 21 Terminals: 17 Gateways: 4 NATed: 2
Cached Endpoints: 1 Terminals: 1 Gateways: 0
-- Call Statistics --
Current Calls: 1 Active: 1 From Neighbor: 0 From Parent: 0
Total Calls: 1539 Successful: 1076 From Neighbor: 60 From Parent: 5
Startup: Fri, 21 Jun 2002 10:50:22 +0800 Running: 11 days 04:22:59
ResetCallCounters
Reset the statistics counters for total calls, successful calls, neighbor calls and parent calls to zero.
PrintAllRegistrations, r, ?
Show all registered endpoints.
Format:
AllRegistrations
RCF|IP:Port|Aliases|Terminal_Type|EndpointID
Number of Endpoints: n
Example:
AllRegistrations
RCF|10.1.1.10:1720|800:dialedDigits=Wei:h323_ID|terminal|1289_endp
RCF|10.0.1.43:1720|613:dialedDigits=Jacky Tsai:h323_ID|terminal|1328_endp
RCF|10.0.1.55:1720|705:dialedDigits=Sherry Liu:h323_ID|terminal|1333_endp
Number of Endpoints: 3
PrintAllRegistrationsVerbose, rv, ??
Show details of all registered endpoints.
Format:
AllRegistrations
Registration_Time C(Active_Call/Connected_Call/Total_Call) <r>
[Prefixes: ##] (gateway only)
Example:
AllRegistrations
RCF|10.0.1.8:1720|Accel-GW2:h323_ID|gateway|1322_endp
Wed, 26 Jun 2002 16:40:03 +0800 C(1/5/33) <1>
Prefixes: 09,002
Wed, 26 Jun 2002 16:40:55 +0800 C(0/32/39) <1>
RCF|10.0.1.66:1720|716:dialedDigits=Vicky:h323_ID|terminal|1425_endp
Wed, 26 Jun 2002 16:40:58 +0800 C(1/47/53) <1>
Number of Endpoints: 2
PrintAllCached, rc
Print list of all cached out-of-zone endpoints.
PrintCurrentCalls, c, !
Show all current calls using the same ACF syntax as in call establishment.
Format:
CurrentCalls
Call No. # | CallID | Call_Duration | Left_Time
Dialed_Number
ACF|Caller_IP:Port|Caller_EPID|CRV|DestinationInfo|SrcInfo|IsAnswered;
ACF|Callee_IP:Port|Callee_EPID|CRV|DestinationInfo|SrcInfo|IsAnswered;
Number of Calls: Current_Call Active: Active_Call From Neighbor: Call_From_Neighbor \
From Parent: Call_From_Parent
Example:
CurrentCalls
Call No. 29 | CallID bd c6 17 ff aa ea 18 10 85 95 44 45 53 54 77 77 | 109 | 491
Dial 0953378875:dialedDigits
ACF|10.0.1.49:1720|4048_CGK1|25263|frank:h323_ID|gunter:h323_ID|false;
ACF|10.1.1.1:1720|4037_CGK1|25263|gunter:h323_ID|frank:h323_ID|true;
Call No. 30 | CallID 70 0e dd c0 9a cf 11 5e 00 01 00 05 5d f9 28 4d | 37 | 563
Dial 0938736860:dialedDigits
ACF|10.0.1.48:1032|4041_CGK1|11896|sue:h323_ID|peter:h323_ID|false;
ACF|10.1.1.1:1720|4037_CGK1|11896|peter:h323_ID|sue:h323_ID|true;
Number of Calls: 2 Active: 2 From Neighbor: 0 From Parent: 0
PrintCurrentCallsVerbose, cv, !!
Show details of all current calls.
Format:
CurrentCalls
Dialed_Number
# Caller_Aliases|Callee_Aliases|Bandwidth|Connected_Time <r>
Number of Calls: Current_Call Active: Active_Call From NB: Call_From_Neighbor
Example:
CurrentCalls
Call No. 48 | CallID 7d 5a f1 0a ad ea 18 10 89 16 00 50 fc 3f 0c f5 | 30 | 570
Dial 0225067272:dialedDigits
ACF|10.0.1.200:1720|1448_endp|19618|frank:h323_ID|gunter:h323_ID|false;
ACF|10.0.1.7:1720|1325_endp|19618|gunter:h323_ID|frank:h323_ID|true;
# Sherry:h323_ID|Accel-GW1:h323_ID|200000|Wed, 26 Jun 2002 17:29:55 +0800 <2>
Number of Calls: 1 Active: 1 From NB: 0
PrintPrefixCapacities, printpc
Print the prefix capacities and current counter values for all endpoints or the specified alias.
Format:
PrintPrefixCapacities [Alias]
PrefixCapacities
-- Endpoint: Alias (1.2.3.4:1720) --
Total calls = 0
prefix/capacity/curr: 125/5/0
-- Endpoint: Alias2 (1.2.3.5:1720) --
Total calls = 0
Example:
PrintPrefixCapacities OpenMCU
PrefixCapacities
-- Endpoint: OpenMCU (192.168.1.100:1720) --
Total calls = 0
prefix/capacity/curr: ^(123|124)/2/0
printcc
Print the current counters for all CapacityControl rules.
Find, f
Find a registered endpoint by an alias or a prefix. To find an alias of the specified type (h323_ID, dialedDigits), prepend the alias type name (h323, e164, url, email) to the alias, followed by a colon.
Format:
Find Alias
Example:
f 800
f 801
Alias 801 not found!
f h323:Wei
FindVerbose, fv
Find details of a registered endpoint by an alias or a prefix. To find an alias of the specified type (h323_ID, dialedDigits), prepend the alias type name (h323, e164, url, email) to the alias, followed by a colon.
Format:
FindVerbose Alias
Example:
fv 02
RCF|10.0.1.100:1720|TFN:h323_ID|gateway|4037_CGK1
Wed, 26 Jun 2002 17:47:29 +0800 C(0/84/120) <1>
Prefixes: 02,09
UnregisterIP
Forcefully unregister an endpoint by IP and call signaling port. If you don't specify a port, the default call signalling port 1720 is used.
Format:
UnregisterIP IP[:Port]
Example:
UnregisterIP 10.0.1.31:1720
URQ|10.0.1.31:1032|1326_endp|maintenance;
Endpoint 10.0.1.31:1720 unregistered!
UnregisterAlias
Forcefully unregister an endpoint by one of its aliases. To match an alias of the specified type (h323_ID, dialedDigits), prepend the alias type name (h323, e164, url, email) to the alias, followed by a colon.
Format:
UnregisterAlias Alias
Example:
UnregisterAlias 601
Endpoint 601 unregistered!
UnregisterAllEndpoints
Forcefully unregister all registered endpoints.
Format:
Example:
URQ|10.0.1.7:1024|1325_endp|maintenance;
URQ|10.0.1.8:1024|1322_endp|maintenance;
URQ|10.0.1.32:1032|1324_endp|maintenance;
URQ|10.0.1.36:1032|1323_endp|maintenance;
URQ|10.0.1.42:1032|1318_endp|maintenance;
Done
DisconnectCall
Disconnect a call with given number (internal, gatekeeper assigned call number, not the caller's, callee's phone number).
Format:
DisconnectCall Number
Example:
DisconnectCall 1533
DisconnectIP
Disconnect all calls of an endpoint by IP and call signaling port.
Format:
DisconnectIP IP[:Port]
Example:
DisconnectIP 10.0.1.31:1720
DisconnectAlias
Disconnect all calls of an endpoint by one of its aliases. To match an alias of the specified type (h323_ID, dialedDigits), prepend the alias type name (h323, e164, url, email) to the alias, followed by a colon.
Format:
DisconnectAlias Alias
Example:
DisconnectAlias 601
ClearCalls
Disconnect all calls on the gatekeeper.
GK
Show the information of the parent gatekeeper.
Trace
Set the status interface output trace level. It controls which messages are sent to this client:
trace 0 or trace min
Only direct responses to commands and reload notifications.
trace 1
CDRs, direct responses to commands and reload notifications.
trace 2 or trace max
Show all (RAS, CDRs, direct responses to commands, reload notifications, etc).
Debug
Only used for debug purpose. Options:
trc [+|-|n]
Show/modify trace level.
cfg SEC PAR
Read and print a config parameter in a section.
set SEC PAR VAL
Write a config value parameter in a section.
remove SEC PAR
Remove a config value parameter in a section.
remove SEC
Remove a section.
printrm VERBOSE
Print all removed endpoint records.
Example:
debug trc 3
debug set RoutedMode H245Routed 1
SetLog
Send trace output to another file.
Format:
Setlog [filename]
Example:
Setlog /tmp/trace.log
RotateLog
Rotate the log file.
Who
Show all people on the status port. First field is the session id, which can be used to disconnect a user through the DisconnectSession command.
DisconnectSession
Disconnect a user from the status port.
Format:
DisconnectSession [session id]
Example:
DisconnectSession 2
Yell, y
Send a message to all status clients.
Format:
Yell [message text]
Example:
Yell Config reload in 5 minutes.
RouteReject
Terminate this call on a virtual queue. This command is used as a response to a RouteRequest event (see below). CallingEndpointID and CallRef must be passed back as they are in the corresponding RouteRequest. The CallID parameter is optional; if it is given it has to be the same format as signaled by RouteRequest.
Format:
RouteReject CallingEndpointID CallRef [CallID]
Example:
RouteReject endp_4711 1234
RouteToAlias, rta
Route this call on a virtual queue to the specified alias. This command is used as a response to a RouteRequest event (see below). CallingEndpointID and CallRef must be passed back as they are in the corresponding RouteRequest. The CallID parameter is optional; if it is given it has to be the same format as signaled by RouteRequest.
Format:
RouteToAlias Alias CallingEndpointID CallRef [CallID]
Example:
RouteToAlias Suzi endp_4711 1234
RouteToGateway, rtg
Route this call on a virtual queue to the specified alias and set the destinationSignalAddress. This command is used as a response to a RouteRequest event (see below). You can use this command to route calls to out-of-zone gateways or MCUs not registered with the gatekeeper. Make sure that the 'vqueue' and 'explicit' policy is in effect for these calls. CallingEndpointID and CallRef must be passed back as they are in the corresponding RouteRequest. The CallID parameter is optional; if it is given it must be the same format as signaled by RouteRequest.
Format:
RouteToGateway Alias IP:Port CallingEndpointID CallRef [CallID]
Example:
RouteToGateway Suzi 192.168.0.50 endp_4711 1234
SendProceeding
WARNING: This is an experimental feature.
Send a CallProceeding message to the caller. The only time this makes sense is after a RouteRequest event for an unregistered call. Otherwise a status port application won't know if a Setup message has been sent but that the call is not yet established.
Format:
SendProceeding CallID
Example:
SendProceeding 40-06-dd-98-22-37-52-40-8c-b0-92-0e-18-60-99-07
Exit, Quit, q, Ctrl-D
Quit the status port.
TransferCall
Transfer an established call from alias A to alias B.
This works only with endpoints that properly support Q.931 Facility messages (so it doesn't work with Netmeeting).
Format:
TransferCall Source-Alias New-Destination-Alias
Example:
TransferCall Frank Peter
MakeCall
Generate a new call from source to destination alias. You can also specify an IP number as destination. This is done by establishing a call from a pseudo endpoint in the gatekeeper to the source alias/number and then transferring the call from the gatekeeper endpoint to the destination.
The transfer can be done using either a H.450.2 transfer or a Facility message.
See [CTI::MakeCall] for configuration options.
Format:
MakeCall Source-Alias Destination-Alias
Example:
MakeCall 1234 5678
MakeCall joe 192.168.6.1
GetAuthInfo,gai
Gather information from a specific authentication module (if it provides such information) and displays it on the status port.
Format:
GetAuthInfo ModuleName
Example:
GetAuthInfo RadAliasAuth
GetAcctInfo,gci
Gather information from a specific accounting module (if it provides such information) and displays it on the status port.
Format:
GetAcctInfo ModuleName
Example:
GetAcctInfo SqlAcct
