A2Billing 1.3 - Help - Add or Edit Alarm
โพสต์โดย nuiz » 24 เม.ย. 2010 08:43
Add or Edit and Alarm
This screen allows you to set up alarms to monitor the trunks.
Name
Give it a memorable Name
Period
When to check the status of the alarms you have set up
Alarm Type
What to monitor
•ALOC - Average Length of Call
•ASR - Answer Seize Ratio
•CIC - Consecutive Incomplete Calls
Min and Max Values
Depending on what alarm type is selected will depend on the number to put in these fiels. Read the on screen docs for hints
Trunk
Trunk to Monitor
Status
Active or inactive
Email to Send Alarm
Put in your email address.
