A2Billing 1.3 - Help - Rate Card Simulator
โพสต์โดย nuiz » 23 เม.ย. 2010 17:45
Rate Card Simulator
The rate card simulator is for the purpose of checking that the calculated rate against a card is correct.
It will return all details about the different routes available for that card.
Enter the number to check, then select the card number to check, and therefore the callplan, then click simulate.
โพสต์: 7651
