A2Billing 1.3 - Help - Browse Rates
โพสต์โดย nuiz » 23 เม.ย. 2010 17:42
Browse Rates
Browse rates allows you to filter rates, search for individual rates, access to edit them, and also to bulk update rates.
Search Rates
Click search rates at the top of the page to search on various criteria for a rate or subset of rates.
Batch Update
Having found the desired subset of rates, a batch update can be applied to them.
Chose a Ratecard
The rates belonging to an individual ratecard can be selected using this dropdown.
Filter on Dial Prefix
Find all rates that begin with the dial prefix typed into this field.
Field List
Destination
The destination name.
Prefix
The prefix for the rate. A dialled number is matched in the following way:-
•Compare dialled digits against all prefixes
•If match, set rate and dial call
•If no match, strip the last digit off dialstring and compare against all prefixes. Continue until match.
•If no digits remaining it matches the 'defaultprefix', a catch-all rate used only when no better match could be found.
Note that if you don't have a prefix 'defaultprefix', there is no match, and A2Billing will not allow the call to go through.
BR
Buying Rate, the rate you get from your carrier
SR
Your retail rate
Start Date
Start date of rate - inherited from the ratecard, unless it is changed manually
Stop Date
Stop date of rate - inherited from the ratecard, unless it is changed manually
INITB
Init Block, the minimum duration that the call is charged for.
Connect Charge
Any connection charge applied to this rate.
Trunk
The Trunk used.
FTC
If a package is used, then this denotes whether or not this destination is included in the free minutes package. Set to 1 to count this destination in FT2C packages.
Action
•Edit - Edit Rate see Add Rate
•Delete - Delete Rate
Export
The system allows for rates to be exported to CSV or XML
