A2Billing 1.3 - Help - List Ratecards
โพสต์โดย nuiz » 23 เม.ย. 2010 17:38
List Ratecard
This screen lists all the ratecards on the system.
The headings are as follows:-
ID
A numeric identity incremented by one each time a new rate table is added.
Tariff name
The name of the ratecard. A recommended naming convention is to name the ratecard with both the product and the carrier that ratecard uses.
Start Date
The date when the ratecard becomes active.
Expiry Date
The date that the ratecard expires. These two attributes can be used to do a customer rate change, or to offer special prices on certain days of the year - e.g. Christmas.
Trunk
The trunk used by this ratecard
Minutes Used
The number of minutes passed through this ratecard.
DNID Prefix
Select the ratecard depending on the access number
CID Prefix
Select the ratecard on the Caller ID.
Action
•Delete - delete the ratecard
•Edit the Ratecard - see [url]1-3-EditRatecard[/url]
Confirm data to apply changes
