5. ติดตั้ง Vicidial
5. ติดตั้ง Vicidial
โพสต์โดย nuiz » 07 พ.ค. 2017 00:28
ล๊อกอินเข้า Vicibox เป็น root
ดาวน์โหลดซอร์สโค๊ดจาก svn
vicidial-install
cd /usr/src/astguiclient/trunk
perl install.pl
Would you like to use manual configuration and installation(y/n): [y]
STARTING ASTGUICLIENT MANUAL CONFIGURATION PHASE...
astguiclient configuration file or press enter for default: [/etc/astguiclient.conf]
astguiclient home path or press enter for default: [/usr/share/astguiclient]
/usr/share/astguiclient does not exist, would you like me to create it?(y/n) [y]
/usr/share/astguiclient directory created
astguiclient logs path or press enter for default: [/var/log/astguiclient]
/var/log/astguiclient does not exist, would you like me to create it?(y/n) [y]
/var/log/astguiclient directory created
asterisk agi-bin path or press enter for default: [/var/lib/asterisk/agi-bin]
server webroot path or press enter for default: [/usr/local/apache2/htdocs] /srv/www/htdocs
/var/www/html does not exist, would you like me to create it?(y/n) [y]
/var/www/html directory created
asterisk sounds path or press enter for default: [/var/lib/asterisk/sounds]
asterisk monitor path or press enter for default: [/var/spool/asterisk/monitor]
asterisk DONEmonitor path or press enter for default: [/var/spool/asterisk/monitorDONE]
server IP address or press enter for default: [192.168.2.25]
DB server address or press enter for default: [localhost]
DB database name or press enter for default: [asterisk]
DB user login or press enter for default: [cron] root
DB user password or press enter for default: [1234] password
DB custom user login or press enter for default: [custom] root
DB custom password login or press enter for default: [custom1234] password
DB connection port or press enter for default: [3306]
Numeric list of the astGUIclient processes to be kept running
(value should be listing of characters with no spaces: 123456)
X - NO KEEPALIVE PROCESSES (use only if you want none to be keepalive)
1 - AST_update
2 - AST_send_listen
3 - AST_VDauto_dial
4 - AST_VDremote_agents
5 - AST_VDadapt (If multi-server system, this must only be on one server)
6 - FastAGI_log
7 - AST_VDauto_dial_FILL (only for multi-server, this must only be on one server)
8 - ip_relay (used for blind agent monitoring)
9 - Timeclock auto logout
E - Email processor, (If multi-server system, this must only be on one server)
Enter active keepalives or press enter for default: [1234568]
Enter the Asterisk version that you are installing VICIDIAL for
(value should be only one of the options below:)
1.2
1.4
1.8
11.X
Enter asterisk version or press enter for default: [1.4] 11.X
Copy sample configuration files to /etc/asterisk/ ? [n] y
Copy web language translation files to webroot ? [] y
FTP host address or press enter for default: [10.0.0.4] 192.168.2.25
FTP user login or press enter for default: [cron] root
FTP user password or press enter for default: [test] password
FTP connection port or press enter for default: [21]
FTP directory or press enter for default: [RECORDINGS]
HTTP path for archive or press enter for default: [http://10.0.0.4] http://192.168.2.25
REPORT host address or press enter for default: [10.0.0.4] 192.168.2.25
REPORT user login or press enter for default: [cron] root
REPORT user password or press enter for default: [test] password
REPORT connection port or press enter for default: [21]
REPORT directory or press enter for default: [REPORTS]
FastAGI log minimum child servers: [3]
FastAGI log maximum child servers: [16]
FastAGI log minimum spare child servers: [2]
FastAGI log maximum spare child servers: [8]
FastAGI log maximum requests per child server: [1000]
FastAGI log check-for-dead seconds: [30]
FastAGI log check-for-wait seconds: [60]
defined conf file: /etc/astguiclient.conf
defined home path: /usr/share/astguiclient
defined logs path: /var/log/astguiclient
defined agi-bin path: /var/lib/asterisk/agi-bin
defined webroot path: /var/www/html
defined sounds path: /var/lib/asterisk/sounds
defined monitor path: /var/spool/asterisk/monitor
defined DONEmonitor path: /var/spool/asterisk/monitorDONE
defined server_ip: 192.168.2.25
defined DB_server: localhost
defined DB_database: asterisk
defined DB_user: root
defined DB_pass: dmt032017
defined DB_custom_user: root
defined DB_custom_pass: dmt032017
defined DB_port: 3306
defined active_keepalives: 1234568
defined asterisk_version: 11.X
defined copying conf files: y
defined copying weblang files: y
defined FTP_host: 192.168.2.25
defined FTP_user: root
defined FTP_pass: dmt032017
defined FTP_port: 21
defined FTP_dir: RECORDINGS
defined HTTP_path: http://192.168.2.25
defined REPORT_host: 192.168.2.25
defined REPORT_user: root
defined REPORT_pass: dmt032017
defined REPORT_port: 21
defined REPORT_dir: REPORTS
defined fastagi_log_min_servers: 3
defined fastagi_log_max_servers: 16
defined fastagi_log_min_spare_servers: 2
defined fastagi_log_max_spare_servers: 8
defined fastagi_log_max_requests: 1000
defined fastagi_log_checkfordead: 30
defined fastagi_log_checkforwait: 60
Are these settings correct?(y/n): [y] y
Gathering expected DB Schema version...
Gathering expected DB Schema version found: |1504|
Writing to configuration file: /etc/astguiclient.conf
STARTING ASTGUICLIENT INSTALLATION PHASE...
Creating /usr/share/astguiclient/LEADS_IN directories...
Creating /var/spool/asterisk/monitor directories...
Creating /var/log/astguiclient/archive directory for backups...
Copying bin scripts to /usr/share/astguiclient ...
Copying libs to /usr/share/astguiclient ...
setting cron scripts to executable...
Copying extras files to /usr/share/astguiclient ...
Copying agi-bin scripts to /var/lib/asterisk/agi-bin ...
setting agi-bin scripts to executable...
Copying sounds to /var/lib/asterisk/sounds...
Creating sound tts directories...
Copying ip_relay scripts to /usr/share/astguiclient...
Setting ip_relay scripts to executable...
Starting ip_relay port forwarding for IAX on 40569, 41569 and 42569
Creating /var/www/html web directories...
Copying web files...
setting web scripts to executable...
Static language files no longer available, use dynamic language features.
Copying sample conf files to /etc/asterisk/...
Creating auto-generated placeholder conf files in /etc/asterisk/...
Updating version information in the database...
|UPDATE servers SET svn_revision='2748',svn_info='/usr/src/astguiclient/trunk
Path: .
Working Copy Root Path: /usr/src/astguiclient/trunk
URL: svn://svn.eflo.net/agc_2-X/trunk
Relative URL: ^/agc_2-X/trunk
Repository Root: svn://svn.eflo.net
Repository UUID: 3d104415-ff17-0410-8863-d5cf3c621b8a
Revision: 2748
Node Kind: directory
Schedule: normal
Last Changed Author: mattf
Last Changed Rev: 2748
Last Changed Date: 2017-05-05 23:32:42 +0700 (Fri, 05 May 2017)
' where server_ip='192.168.2.25';|
|UPDATE system_settings SET svn_revision='2748';|
Version information updated: 2748|192.168.2.25
ASTGUICLIENT VICIDIAL INSTALLATION FINISHED! ENJOY!
- process runtime (170 sec) (2.83333333333333 minutes)
คอนฟิกทั้งหมดนี้เก็บอยู่ในไฟล์ /etc/astguiclient.conf
ย้อนกลับไปยัง VICIbox - VICIDIAL Call Center Suite
