4.0 สั่ง service ให้สตาร์ทอัตโนมัติ
โพสต์โดย nuiz » 06 พ.ค. 2017 19:02
รันคำสั่งนี้
chkconfig vicidial on
service vicidial start
จะสตาร์ททุกโปรแกรมที่เกี่ยวข้อง เช่น asterisk
ตรวจสอบ
service vicidial status
ผลลัพธ์
vicidial.service - LSB: ViciDial Telephony Server
Loaded: loaded (/etc/init.d/vicidial)
Active: active (running) since Sun 2017-05-07 01:34:22 +07; 1min 24s ago
Process: 3784 ExecStart=/etc/init.d/vicidial start (code=exited, status=0/SUCCESS)
CGroup: /system.slice/vicidial.service
â”─3835 /usr/bin/SCREEN -S asterisk
â”─3836 /bin/sh
â”─3840 /usr/sbin/asterisk -vvvvgcT
â”─3848 ip_relay 40569 127.0.0.1 4569 9999999
â”─3849 ip_relay 41569 127.0.0.1 4569 9999999
└─3850 ip_relay 42569 127.0.0.1 4569 9999999
May 07 01:34:14 vicibox vicidial[3784]: Loading dahdi_dummy module... failed.
May 07 01:34:14 vicibox vicidial[3784]: Fallback to dahdi module... done.
May 07 01:34:19 vicibox vicidial[3784]: Initializing DAHDI Hardware... done.
May 07 01:34:19 vicibox vicidial[3784]: Resetting vars and rolling logs... done.
May 07 01:34:22 vicibox vicidial[3784]: Starting Asterisk... PID 3840, done.
May 07 01:34:22 vicibox vicidial[3784]: Giving asterisk -1 process priority... done.
May 07 01:34:22 vicibox vicidial[3784]: Starting ip_relay with OS specific version... done.
May 07 01:34:22 vicibox vicidial[3784]: ViciDial Telephony Server Started. Log at /var/log/vicidial.log
May 07 01:34:22 vicibox vicidial[3784]: ..done
May 07 01:34:22 vicibox systemd[1]: Started LSB: ViciDial Telephony Server.
ทดสอบเข้า Asterisk Console
asterisk -rvvvvv
[May 7 01:36:28] Asterisk 11.25.1-vici, Copyright (C) 1999 - 2013 Digium, Inc. and others.
[May 7 01:36:28] Created by Mark Spencer <markster@digium.com>
[May 7 01:36:28] Asterisk comes with ABSOLUTELY NO WARRANTY; type 'core show warranty' for details.
[May 7 01:36:28] This is free software, with components licensed under the GNU General Public
[May 7 01:36:28] License version 2 and other licenses; you are welcome to redistribute it under
[May 7 01:36:28] certain conditions. Type 'core show license' for details.
[May 7 01:36:28] =========================================================================
[May 7 01:36:28] Connected to Asterisk 11.25.1-vici currently running on vicibox (pid = 3840)
vicibox*CLI>
vicibox*CLI>
ด้านล่างนี้ยกเลิกทั้งหมด
mysql
apache2
asterisk
แล้ว save
จากนั้นก็จะเข้าหน้าเว็บ ViciBox ได้
ย้อนกลับไปยัง VICIbox - VICIDIAL Call Center Suite
