Update 2.4 ไป 2.5 แล้วเบอร์ภายในโทรหากันไม่ได้
โพสต์โดย sirom » 08 มิ.ย. 2016 15:17
Asterisk 11.21.0, Copyright (C) 1999 - 2013 Digium, Inc. and others.
Asterisk comes with ABSOLUTELY NO WARRANTY; type 'core show warranty' for detail s.
Connected to Asterisk 11.21.0 currently running on elastix24 (pid = 4504)
[2016-06-08 14:57:32] WARNING[4637][C-00000000]: ast_expr2.fl:470 ast_yyerror: a st_yyerror(): syntax error: syntax error, unexpected '>', expecting $end; Input :
> 0
[2016-06-08 14:57:32] WARNING[4637][C-00000000]: ast_expr2.fl:474 ast_yyerror: I f you have questions, please refer to https://wiki.asterisk.org/wiki/display/AST /Channel+Variables
[2016-06-08 14:57:32] WARNING[4637][C-00000000]: func_logic.c:192 acf_if: Syntax IF(<expr>?[<true>][:<false>]) (expr must be non-null, and either <true> or <fa lse> must be non-null)
[2016-06-08 14:57:32] WARNING[4637][C-00000000]: func_logic.c:193 acf_if: In this case, <expr>='', <true>='', and <false>='15'
[2016-06-08 14:58:10] WARNING[4638][C-00000001]: ast_expr2.fl:470 ast_yyerror: ast_yyerror(): syntax error: syntax error, unexpected '>', expecting $end; Input:
> 0
[2016-06-08 14:58:10] WARNING[4638][C-00000001]: ast_expr2.fl:474 ast_yyerror: If you have questions, please refer to https://wiki.asterisk.org/wiki/display/ ... +Variables
[2016-06-08 14:58:10] WARNING[4638][C-00000001]: func_logic.c:192 acf_if: Syntax IF(<expr>?[<true>][:<false>]) (expr must be non-null, and either <true> or <false> must be non-null)
[2016-06-08 14:58:10] WARNING[4638][C-00000001]: func_logic.c:193 acf_if: In this case, <expr>='', <true>='', and <false>='15'
[2016-06-08 14:59:35] WARNING[4639][C-00000002]: ast_expr2.fl:470 ast_yyerror: ast_yyerror(): syntax error: syntax error, unexpected '>', expecting $end; Input:
> 0
[2016-06-08 14:59:35] WARNING[4639][C-00000002]: ast_expr2.fl:474 ast_yyerror: If you have questions, please refer to https://wiki.asterisk.org/wiki/display/ ... +Variables
[2016-06-08 14:59:35] WARNING[4639][C-00000002]: func_logic.c:192 acf_if: Syntax IF(<expr>?[<true>][:<false>]) (expr must be non-null, and either <true> or <false> must be non-null)
[2016-06-08 14:59:35] WARNING[4639][C-00000002]: func_logic.c:193 acf_if: In this case, <expr>='', <true>='', and <false>='15'
[2016-06-08 14:59:43] WARNING[4640][C-00000003]: ast_expr2.fl:470 ast_yyerror: ast_yyerror(): syntax error: syntax error, unexpected '>', expecting $end; Input:
> 0
[2016-06-08 14:59:43] WARNING[4640][C-00000003]: ast_expr2.fl:474 ast_yyerror: If you have questions, please refer to https://wiki.asterisk.org/wiki/display/ ... +Variables
[2016-06-08 14:59:43] WARNING[4640][C-00000003]: func_logic.c:192 acf_if: Syntax IF(<expr>?[<true>][:<false>]) (expr must be non-null, and either <true> or <false> must be non-null)
[2016-06-08 14:59:43] WARNING[4640][C-00000003]: func_logic.c:193 acf_if: In this case, <expr>='', <true>='', and <false>='15'
[2016-06-08 14:59:52] WARNING[4641][C-00000004]: ast_expr2.fl:470 ast_yyerror: ast_yyerror(): syntax error: syntax error, unexpected '>', expecting $end; Input:
> 0
[2016-06-08 14:59:52] WARNING[4641][C-00000004]: ast_expr2.fl:474 ast_yyerror: If you have questions, please refer to https://wiki.asterisk.org/wiki/display/ ... +Variables
[2016-06-08 14:59:52] WARNING[4641][C-00000004]: func_logic.c:192 acf_if: Syntax IF(<expr>?[<true>][:<false>]) (expr must be non-null, and either <true> or <false> must be non-null)
[2016-06-08 14:59:52] WARNING[4641][C-00000004]: func_logic.c:193 acf_if: In this case, <expr>='', <true>='', and <false>='15'
[2016-06-08 15:00:08] WARNING[4648][C-00000005]: ast_expr2.fl:470 ast_yyerror: ast_yyerror(): syntax error: syntax error, unexpected '>', expecting $end; Input:
> 0
[2016-06-08 15:00:08] WARNING[4648][C-00000005]: ast_expr2.fl:474 ast_yyerror: If you have questions, please refer to https://wiki.asterisk.org/wiki/display/ ... +Variables
[2016-06-08 15:00:08] WARNING[4648][C-00000005]: func_logic.c:192 acf_if: Syntax IF(<expr>?[<true>][:<false>]) (expr must be non-null, and either <true> or <false> must be non-null)
[2016-06-08 15:00:08] WARNING[4648][C-00000005]: func_logic.c:193 acf_if: In this case, <expr>='', <true>='', and <false>='15'
[2016-06-08 15:04:37] NOTICE[4524]: chan_sip.c:23841 handle_response_peerpoke: Peer '105' is now Reachable. (18ms / 2000ms)
[2016-06-08 15:04:38] NOTICE[4524]: chan_sip.c:23841 handle_response_peerpoke: Peer '103' is now Reachable. (63ms / 2000ms)
แก้ยังไงครับ
sirom
โพสต์: 27
ลงทะเบียนเมื่อ: 30 เม.ย. 2011 20:18
Re: Update 2.4 ไป 2.5 แล้วเบอร์ภายในโทรหากันไม่ได้
โพสต์โดย sirom » 08 มิ.ย. 2016 16:04
ตาลาย ลงผิดกลุ่มครับ
sirom
โพสต์: 27
โพสต์โดย sirom » 08 มิ.ย. 2016 18:15
มีวิธีแก้ไขไหมครับ หรือต้องกลับไป 2.4 เหมือนเดิม แต่เบอร์ registered ได้นะครับ
sirom
โพสต์: 27
โพสต์โดย nuiz » 08 มิ.ย. 2016 21:10
สวัสดีครับ
ผมย้ายหัวข้อให้แล้วครับ
เวอร์ชั่น 2.5 ทำงานได้ปกตินะครับ แต่เวอร์ชั่นนี้ก็มีอัพเดทมาเรื่อยๆ ผมเคยอัพจาก 2.4 -> 2.5 ก็ยังทำงานได้ แต่นั่นเมื่อปีที่แล้วครับ ตอนนี้ไม่รู้ว่าถ้าอัพเดทจะเป็นอะไรมั๊ย
ผมว่าโค๊ดในไฟล์ extensions_additional.conf มันมั่วหน่ะครับ โค๊ดก็ผิดด้วย มันเลยทำงานไม่ถูก ลองอัพเกรดใหม่ หรือไม่ก็ลงเครื่องใหม่เลยดีกว่าครับ
ไม่ก็ลองกด submit -> apply ในหน้าคอนฟิก elastix หรือเข้าหน้า freepbx ไปคอนฟิกอะไรก็ได้ในหน้า extensions กด submit -> apply เป็นการล้างไฟล์ extensions_additional.conf ใหม่ อาจช่วยได้
ผมว่าต้นตอจริงๆน่าจะมาจากโค๊ดของ Elastix/FreePBX ครับ เวลามันไรท์เป็นไฟล์ extensions_additional.conf มันเลยมั่ว
ลองแบบนี้...
1. เข้า FreePBX แล้วไป Uninstall โมดูลใน Module Admin ออก โมดูหลักๆไม่ต้องเอาออก เช่น Core Framework
2. ติดตั้งโมดูลเหล่านั้นกลับเข้าไปใหม่
3. กด Submit -> Apply
4. เทสการใช้งาน
5. ถ้าไม่ได้... ลงใหม่
โพสต์: 7651
โพสต์โดย sirom » 09 มิ.ย. 2016 11:02
ไม่สำเร็จครับ ตอนนี้ ลง 2.4 ใหม่ แล้ว restore กลับ ใช้ได้ครับ
ส่วน 2.5 จะลงใหม่แล้ว config ใหม่เลยครับ
ปล. ลืมการ config กับ dag1000-80 ที่ซื้อจากคุณหนุ่ยไปแล้วครับ ใช้มาหลายปียังใช้ดีอยู่ครับ
sirom
โพสต์: 27
กำลังดูบอร์ดนี้: Google [Bot] และ บุคคลทั่วไป 1 ท่าน
