KZ iSurf 1008 VoIP Broadband Media Gateway
โพสต์โดย voip4share » 12 ก.พ. 2010 17:53
iSurf 1008
iSurf VoIP Gateway Data Sheet.pdf
iSurf Product Datasheet
(1.09 MiB) ดาวน์โหลด 443 ครั้ง
Features
- Support multiple deployment scenarios
- Call control protocols SIP, H.323, MGCP
- Support data and voice QoS
- Support multiple network management options
- Support local billing
- Support PoE (optional)
- Perfect Solution for Integraded Broadband Service Access
Designed and developed by KZ Broadband Technologies, the iSurf 1008 is an integraded access device (IAD) that combined the capabilities of a residential voice gateway and a residential switch/hub. It is equipped with 4 analog phone ports, one 10/100Mbps WAN link port and one 10/100 Mbps LAN port. As the integraded access device, the iSurf 1008 connectes POTS phone, PCs, IP set top boxes and other types of data devices to the broadband network via its Ethernet WAN port.
-Simple to manage
Supports local management access, Telnet, Web, SNMP v1/2/3, and remote online upgrade. Centrialized provision and upgrade management support via KZ Tech iManager 2000 product.
Advanced Features
The iSurf 1008 provides a complete set of voice gateway featres, and it can readily provide IP phone services when deployed in conjuction with the Soft Switch and the VoIP Gateway in a carrier network. It also support 802.1p/q with superior QoS capabilities, ensuring the reliable transmission of voice services.
- Support both data and voice
Privides unified access to broadband IP voice, vide and data simultaneously. Support 802.1p/q, ToS or DSCP marking of VoIP service, and QoS priorities at multiple virtual interfaces, ensuring greater service feasibility and reliability.
- Rich feature set
Support NAT/Firewall penetration, plug & play, roaming, authentication, voice encryption PSTN bypass, dual-mode calls (PSTN/IP), PPPoE authentication, and Z interface polarity reversal designed for ease of billing.
- Flexible to deploy
The compact design is well suited for home, SOHO and enterprise applications. The IP addresses can be statically allocated or dynamically obtained via DHCP.
Specification
Physical
Dimension 240 mm x 180 mm x 45 mm
Weight < 1 Kg
Power Consumption < 15 W
Power Supply 12 VDC
Environmental
Temperature -5C to 50C
Humidity 90% maximum non-condening
System
Interface 1x10/100 Mbps WAN, 1x10/100 Mbps LAN, 8xRJ11 analog phone ports
LED System status, Power status, Phone Status, Ethernet port status
Voice transmission distance 3 Km - 5 Km
Voice
Compression G.711, G.723.1, G.729a
Comfort Noise Comport noise insertion and level control
Echo Cancellation G.165/G.168-2000 echo cancellation
Silence Suppression Silence detection and suppression
Fax T.30/T.38
Delay/Jitter/Loss Delay, Jitter, Packet Loss compensation
DTMF Relay Inband DTMF Relay and RFC 2833
Call Duration Uninterrupted for > 48 hours continously
Service
Basic voice
- Local and domestic/international long distance calls
- Flexible dial plan configuration support
Complementary Voice Services
- Caller ID, Caller ID suppression, call screening, speed dial, call tracing, hotline, unconditional call forwarding, call forwarding when no answer, call forwarding when busy, call waiting, call back, call blocking, no disturbance, alarm, 2-way call etc.
Data
- Supports routing functionality for dedicated data access by user PC, set top box and etc.
- Supports DHCP or static IP address assignment
- Supports VLAN, TOS, or DSCP tagging for service differentiation and QoS prioritiation
- Supports Plug and Play and multi-service application
Networking
- Soft Switch based network configuration IAD inter-working
Industrial Standards
- IEEE 802.3, 802.3u, 802.1p (CoS Priority Prococol), 802.1Q (Vlan Tagging)
- IETF IP Voice SIP/H.323/MGCP
Security Criterion
- FCC Part 15, 68
Additional Features
- NAT/Firewall traversal, PPPoE authentication, VoIP encryption, Z interface polarity reversal
Management
- Local console, Telnet, Web, SNMP v1,2,3, Remote online upgrade, Centralizted management via i Manager 2000
