แนะนำ Gateway FXO ,FXS (์NGN Support)
ตัวแทนจำหน่ายสินค้าวีโอพีในในประเทศไทย
กฎการใช้บอร์ด
โพสต์สินค้าที่มีจำหน่ายได้เลยครับ แต่ขอเฉพาะที่เกี่ยวกับวีโอไอพีนะครับ
โพสต์โดย SunCTI » 09 ก.ย. 2014 16:17
SAG1000 Gateway
HIGHT LIGHT
 4-8 Ports FXS/FXO
 Cost-effective
 SIP Standard
 SIP TCP (For Lync server)
 NGN Network support
Main Feature
Easy to operate and maintain
SAG1000 supports both web-based and text-based configuration set up. Users can remote-ly upgrade the software, Capture Voice streaming/SIP message, change the configura-tion parameters, download log files.
High Interoperability
SAG1000 has passed the interoperability tests with many softswitch and gateway suppliers worldwide, such as Huawei,ZTE, Cisco, Alcatel, Lucent, Panasonic, NEC, Harris, Nortel, and open source hosted IPPBX asterisk.
FAX over IP (T.38/Pass-through)
SAG1000 support FAXT.38 as default. FAX T.38 is the preferred method for FAX over TCP/IP because it is more reliable and works well in most network conditions. Anyway, If the ser-vice provider does not support T.38, FAX pass-through mode may be applied.
Investment Protection
One main challenge of purchasing new IP-based voice equipment's is how to protect your investment. SAG1000 not only offers the best cost effectiveness but also supports the latest VoIP technologies and of the
standards. Users can take advantage newest VoIP technologies by upgrading SAG1000 software.
SAG1000 is a perfect product for the telecom carriers to provide the residential telephony, NGN,radio over IP and fax services through the IP networks such as MPLS, HFC, and ADSL. It can be connected to the traditional Radio sys-tem, PBXs to provide the voice solutions for Large enterprises, Government, and SME. It can also serve as a hotline service for remote terminal (peer-peer).
SAG1000 Gateway
Specification
Network
•NAT (Rout and Bridge)
•Static IP, PPPoE, DHCP
•DHCP server
•MAC address clone
•DMZ, Static routing
•IP,TCP, UDP,TFTP, FTP, TCP,ARP,RARP, Ping, NTP, SNTP, Http, DNS, Trancert, IPV4,NGN network
•Static/dynamic ARP
Call Features
•Call waiting
•Call transfer(Blind transfer, Attend Transfer ,Half blind transfer)
•Quick pick
•Call forwarding
•Hotline
•Call hold
•DND
•3-way conference(1/2/4FXS Support)
•Voice mail
•Direct IP address call
TECHNICAL SPECIFICATIONS
Physical Interfaces
• 4-8 FXS/O RJ11 connector
• 1 x port Ethernet 10/100 BaseT RJ45 connector
VoIP Specifications
•G.711A/U law, G.723.1, G.729A/B
•Comfort Noise Generation(CNG)
•Voice Activity Detection(VAD)
•Echo Cancellation(G.168)
•Adaptive (Dynamic) Jitter Buffer
•Hook flash test
•Programmable Gain Control ( TX/RX gain adjust)
•T.38/Pass-through/Modem FAX mode, Up to 14.4kbps
•DTMF mode: Signal/RFC2833/INBAND
SIP Protocol
• SIP V2.0 RFC( 3261,3262,3264) ,SIP REFER (RFC
3515) ,SIP TCP (FXS model only)
• RTP/RTCP (RFC 1889,1890)
• STUN (RFC 3489)
• ARP/RARP (RFC 826/903)
• SNTP (RFC 2030)
• DHCP/PPPoE
• TFTP/HTTP/HTTPS
• DNS/DNS SRV (RFC 1706/RFC 2782)
• VLAN 802.1P/802.1Q
Compatibility
•Fully compatible with mainstream venders, such as HUAWEI softX3000, elastix, trixbox, voipswitch, aster-isk etc.
•Compatible with other standard Soft Switch and SIP server
Environment
•Power: input:100-240V,50-60HzOutput: 12VDC,1A
•Power consumption (w): 20w
•Temperature (operator): 0 ℃~ 45 ℃ (storage): -20 ℃~80 ℃
•Humidity: 10%-90% no condensation
Dimension
•4FXS/O , 8FXS/O : 242(L)*152(W)*40(H)mm
SAG1000 Gateway
Specification
Call Routing
•Port group
•IP trunk
•Primary and secondary SIP account
•32inbound/outbound routing
•Number manipulation
•Dial plan set
Management
•Web based configuration
•Telnet configuration
•Data backup/restore
•Support English and Chinese language
•Firmware upgrade by TFTP
•Sys log and CDR
•Web & telnet login password modify
•Factory reset
•Automatic time synchronization
•OoS
•SNMP
•LED Indicator status display
For more information
Please visit: www.suncti.co.th or call 66-2-9610991-94 , mobile 092 270 8845 or email : next@suncti.co.th
SunCTI Technology Innovation Co.,Ltd.
218/63 Geneva Bldg, room 4/16 Floor 4th,Bangpood, Pakkred Nonthabur 11120 ,Thailand
SunCTI
โพสต์: 5
ลงทะเบียนเมื่อ: 04 ส.ค. 2014 13:40
ย้อนกลับไปยัง ตัวแทนจำหน่ายสินค้า
กำลังดูบอร์ดนี้: ไม่มีสมาชิกใหม่ และ บุคคลทั่วไป 27 ท่าน
