ไฟล์เสียงของ VoipSwitch
Class 5 Softswitch, Billing, Callback, Call Shop, IVR, IP-PBX and more...
โพสต์โดย nuiz » 16 ส.ค. 2012 00:39
เสียงภาษาอังกฤษใน VoipSwitch ครับ เผื่อว่าใครจะอัดใหม่ให้เสียงมันแตกต่างกว่าบริการของคนอื่นๆที่เขาใช้ VoipSwitch เหมือนกัน
เก็บเสียงไว้ใน 2 โฟลเดอร์
c:\Program Files\VoipBox 1.0\languages\English\Waves
c:\Program Files\VoipBox 1.0\languages\English\StaticWaves
ชื่อไฟล์และคำพูด
account_credited.wav = Your account has been credited
dest_busy.wav = The party you're calling is busy
failed_number.wav = Sorry, we're unable to connect your call at this time
failed_pin.wav = You have entered the invalid card number. Please reenter your card number followed by pound key
incorrect_code.wav = Sorry, you have entered the incorrect code
not_sufficient_funds.wav "You do not have sufficient founds on your account"
recharge_enter.wav "Please enter recharge code"
select_language.wav "Please press one for English or two for Spanish"
start_number.wav "Please enter the phone number you wish to reach"
start_pin.wav "Please enter your card number followed by pound key"
voicemail_780.wav "Press seven to delete the message, eight to replay the current message or zero to go to the main menu"
voicemail_789.wav "Press seven to delete the message, eight to replay the current message or nine to play the next message"
voicemail_check_new_messages.wav "Press one to check for new messages"
voicemail_check_old_messages.wav "Press three to check for old messages"
voicemail_check_unheard_messages.wav "Press two to check unheard messages"
voicemail_make_own_message.wav "Press four to record your own welcome message"
voicemail_message_deleted.wav "Message deleted"
voicemail_record_welcome.wav "Record your own welcome message after the tone, press the pound key when finished"
voicemail_start.wav "Welcome to voicemail"
voicemail_welcome_message_not_saved.wav "Your welcome message has not been saved"
voicemail_welcome_message_saved.wav "Your welcome message has been saved"
zero_balance.wav You have zero balance at your account
_voicemail.wav Your call has been transferred to voicemail system, please leave the message after the tone
ไฟล์เสียงในโฟลเดอร์ StaticWaves
0.wav "zero"
1.wav "one"
2.wav "two"
3.wav "three"
4.wav "four"
5.wav "five"
6.wav "six"
7.wav "seven"
8.wav "eight"
9.wav "nine"
10.wav "ten"
11.wav "eleven"
12.wav "twelve"
13.wav "thirteen"
14.wav "fourteen"
15.wav "fifteen"
16.wav "sixteen"
17.wav "seventeen"
18.wav "eighteen"
19.wav "nineteen"
20.wav "twenty"
30.wav "thirty"
40.wav "forty"
50.wav "fifty"
60.wav "sixty"
70.wav "seventy"
80.wav "eighty"
90.wav "ninety"
100.wav "hundred "
1000.wav "thousand"
Better to record more currencies like dollar, dollars or pound, pounds - our grammar is correct for dollar
cent.wav "cent"
cents.wav "cents"
dollar.wav "dollar"
dollars.wav "dollars"
hour.wav "hour"
hours.wav "hours"
minute.wav "minute"
minutes.wav "minutes"
second.wav "second"
seconds.wav "seconds"
you_have.wav "You have"
and.wav "and"
voicemail_message.wav "message"
voicemail_messages.wav "messages"
voicemail_new.wav "new"
voicemail_old.wav "old"
voicemail_unheard.wav "unheard"
voicemail_you_have.wav "You have"
voicemail_you_have_no.wav "You have no"
voicemail_you_have_no_messages.wav "You have no messages"
voicemail_you_have_no_new_messages.wav "You have no new messages"
voicemail_you_have_no_old_messages.wav "You have no old messages"
voicemail_you_have_no_unheard_messages.wav "You have no unheard messages"
zero_balance.wav "You have zero balance on your account"
ย้อนกลับไปยัง VoipSwitch - Affordable Communication Solutions
