โทรออกผ่าน GSM VoIP GW ไม่ได้
โพสต์โดย seringeti_petch » 27 มิ.ย. 2012 08:47
ที่ status ของ SIM มันก็ขึ้น Processing แต่มันไม่โทรออก ลองถอด SIM มาใส่มือถือ ก็โทรได้ปกติ
คือให้เบอร์ 100 โทรเบอร์มือถือ 015705472 ตัด 9 ก่อนครับ ใครเคยเจอช่วยดูด้วยครับ
== Using SIP RTP TOS bits 184
  == Using SIP RTP CoS mark 5
  == Extension Changed 100[ext-local] new state InUse for Notify User 103
    -- Executing [9015705472@from-internal:1] Macro("SIP/100-00002401", "user-callerid,SKIPTTL,") in new stack
    -- Executing [s@macro-user-callerid:1] Set("SIP/100-00002401", "AMPUSER=100") in new stack
    -- Executing [s@macro-user-callerid:2] GotoIf("SIP/100-00002401", "0?report") in new stack
    -- Executing [s@macro-user-callerid:3] ExecIf("SIP/100-00002401", "1?Set(REALCALLERIDNUM=100)") in new stack
    -- Executing [s@macro-user-callerid:4] Set("SIP/100-00002401", "AMPUSER=100") in new stack
    -- Executing [s@macro-user-callerid:5] Set("SIP/100-00002401", "AMPUSERCIDNAME=Yod") in new stack
    -- Executing [s@macro-user-callerid:6] GotoIf("SIP/100-00002401", "0?report") in new stack
    -- Executing [s@macro-user-callerid:7] Set("SIP/100-00002401", "AMPUSERCID=100") in new stack
    -- Executing [s@macro-user-callerid:8] Set("SIP/100-00002401", "CALLERID(all)="Yod" <100>") in new stack
    -- Executing [s@macro-user-callerid:9] ExecIf("SIP/100-00002401", "0?Set(CHANNEL(language)=)") in new stack
    -- Executing [s@macro-user-callerid:10] GotoIf("SIP/100-00002401", "1?continue") in new stack
    -- Executing [s@macro-user-callerid:19] Set("SIP/100-00002401", "CALLERID(number)=100") in new stack
    -- Executing [s@macro-user-callerid:20] Set("SIP/100-00002401", "CALLERID(name)=Yod") in new stack
    -- Executing [s@macro-user-callerid:21] NoOp("SIP/100-00002401", "Using CallerID "Yod" <100>") in new stack
    -- Executing [9015705472@from-internal:2] NoOp("SIP/100-00002401", "Calling Out Route: 9_outside") in new stack
    -- Executing [9015705472@from-internal:3] Set("SIP/100-00002401", "MOHCLASS=default") in new stack
    -- Executing [9015705472@from-internal:4] Set("SIP/100-00002401", "_NODEST=") in new stack
    -- Executing [9015705472@from-internal:5] Macro("SIP/100-00002401", "record-enable,100,OUT,") in new stack
    -- Executing [s@macro-record-enable:1] GotoIf("SIP/100-00002401", "1?check") in new stack
    -- Executing [s@macro-record-enable:4] ExecIf("SIP/100-00002401", "0?MacroExit()") in new stack
    -- Executing [s@macro-record-enable:5] GotoIf("SIP/100-00002401", "0?Group:OUT") in new stack
    -- Executing [s@macro-record-enable:15] GotoIf("SIP/100-00002401", "0?IN") in new stack
    -- Executing [s@macro-record-enable:16] ExecIf("SIP/100-00002401", "1?MacroExit()") in new stack
    -- Executing [9015705472@from-internal:6] Macro("SIP/100-00002401", "dialout-trunk,3,015705472,") in new stack
    -- Executing [s@macro-dialout-trunk:1] Set("SIP/100-00002401", "DIAL_TRUNK=3") in new stack
    -- Executing [s@macro-dialout-trunk:2] GosubIf("SIP/100-00002401", "0?sub-pincheck,s,1") in new stack
    -- Executing [s@macro-dialout-trunk:3] GotoIf("SIP/100-00002401", "0?disabletrunk,1") in new stack
    -- Executing [s@macro-dialout-trunk:4] Set("SIP/100-00002401", "DIAL_NUMBER=015705472") in new stack
    -- Executing [s@macro-dialout-trunk:5] Set("SIP/100-00002401", "DIAL_TRUNK_OPTIONS=tr") in new stack
    -- Executing [s@macro-dialout-trunk:6] Set("SIP/100-00002401", "OUTBOUND_GROUP=OUT_3") in new stack
    -- Executing [s@macro-dialout-trunk:7] GotoIf("SIP/100-00002401", "0?nomax") in new stack
    -- Executing [s@macro-dialout-trunk:8] GotoIf("SIP/100-00002401", "0?chanfull") in new stack
    -- Executing [s@macro-dialout-trunk:9] GotoIf("SIP/100-00002401", "0?skipoutcid") in new stack
    -- Executing [s@macro-dialout-trunk:10] Set("SIP/100-00002401", "DIAL_TRUNK_OPTIONS=") in new stack
    -- Executing [s@macro-dialout-trunk:11] Macro("SIP/100-00002401", "outbound-callerid,3") in new stack
    -- Executing [s@macro-outbound-callerid:1] ExecIf("SIP/100-00002401", "0?Set(CALLERPRES()=)") in new stack
    -- Executing [s@macro-outbound-callerid:2] ExecIf("SIP/100-00002401", "0?Set(REALCALLERIDNUM=100)") in new stack
    -- Executing [s@macro-outbound-callerid:3] GotoIf("SIP/100-00002401", "1?normcid") in new stack
    -- Executing [s@macro-outbound-callerid:6] Set("SIP/100-00002401", "USEROUTCID="Yod" <100>") in new stack
    -- Executing [s@macro-outbound-callerid:7] Set("SIP/100-00002401", "EMERGENCYCID=") in new stack
    -- Executing [s@macro-outbound-callerid:8] Set("SIP/100-00002401", "TRUNKOUTCID=") in new stack
    -- Executing [s@macro-outbound-callerid:9] GotoIf("SIP/100-00002401", "1?trunkcid") in new stack
    -- Executing [s@macro-outbound-callerid:12] ExecIf("SIP/100-00002401", "0?Set(CALLERID(all)=)") in new stack
    -- Executing [s@macro-outbound-callerid:13] ExecIf("SIP/100-00002401", "1?Set(CALLERID(all)="Yod" <100>)") in new stack
    -- Executing [s@macro-outbound-callerid:14] ExecIf("SIP/100-00002401", "0?Set(CALLERID(all)=)") in new stack
    -- Executing [s@macro-outbound-callerid:15] ExecIf("SIP/100-00002401", "0?Set(CALLERPRES()=prohib_passed_screen)") in new stack
    -- Executing [s@macro-dialout-trunk:12] GosubIf("SIP/100-00002401", "0?sub-flp-3,s,1") in new stack
    -- Executing [s@macro-dialout-trunk:13] Set("SIP/100-00002401", "OUTNUM=015705472") in new stack
    -- Executing [s@macro-dialout-trunk:14] Set("SIP/100-00002401", "custom=SIP/GSM_Gateway_out") in new stack
    -- Executing [s@macro-dialout-trunk:15] ExecIf("SIP/100-00002401", "0?Set(DIAL_TRUNK_OPTIONS=M(setmusic^default))") in new stack
    -- Executing [s@macro-dialout-trunk:16] Macro("SIP/100-00002401", "dialout-trunk-predial-hook,") in new stack
    -- Executing [s@macro-dialout-trunk-predial-hook:1] MacroExit("SIP/100-00002401", "") in new stack
    -- Executing [s@macro-dialout-trunk:17] GotoIf("SIP/100-00002401", "0?bypass,1") in new stack
    -- Executing [s@macro-dialout-trunk:18] GotoIf("SIP/100-00002401", "0?customtrunk") in new stack
    -- Executing [s@macro-dialout-trunk:19] Dial("SIP/100-00002401", "SIP/GSM_Gateway_out/015705472,300,") in new stack
    -- Called SIP/GSM_Gateway_out/015705472
    -- SIP/GSM_Gateway_out-00002402 is making progress passing it to SIP/100-00002401
  == Everyone is busy/congested at this time (1:0/1/0)
    -- Executing [s@macro-dialout-trunk:20] NoOp("SIP/100-00002401", "Dial failed for some reason with DIALSTATUS = CONGESTION and HANGUPCAUSE = 34") in new stack
    -- Executing [s@macro-dialout-trunk:21] Goto("SIP/100-00002401", "s-CONGESTION,1") in new stack
    -- Goto (macro-dialout-trunk,s-CONGESTION,1)
    -- Executing [s-CONGESTION@macro-dialout-trunk:1] Set("SIP/100-00002401", "RC=34") in new stack
    -- Executing [s-CONGESTION@macro-dialout-trunk:2] Goto("SIP/100-00002401", "34,1") in new stack
    -- Goto (macro-dialout-trunk,34,1)
    -- Executing [34@macro-dialout-trunk:1] Goto("SIP/100-00002401", "continue,1") in new stack
    -- Goto (macro-dialout-trunk,continue,1)
    -- Executing [continue@macro-dialout-trunk:1] GotoIf("SIP/100-00002401", "1?noreport") in new stack
    -- Goto (macro-dialout-trunk,continue,3)
    -- Executing [continue@macro-dialout-trunk:3] NoOp("SIP/100-00002401", "TRUNK Dial failed due to CONGESTION HANGUPCAUSE: 34 - failing through to other trunks") in new stack
    -- Executing [continue@macro-dialout-trunk:4] Set("SIP/100-00002401", "CALLERID(number)=100") in new stack
    -- Executing [9015705472@from-internal:7] Macro("SIP/100-00002401", "outisbusy,") in new stack
    -- Executing [s@macro-outisbusy:1] Progress("SIP/100-00002401", "") in new stack
    -- Executing [s@macro-outisbusy:2] GotoIf("SIP/100-00002401", "0?emergency,1") in new stack
    -- Executing [s@macro-outisbusy:3] GotoIf("SIP/100-00002401", "0?intracompany,1") in new stack
    -- Executing [s@macro-outisbusy:4] Playback("SIP/100-00002401", "all-circuits-busy-now&pls-try-call-later, noanswer") in new stack
    -- <SIP/100-00002401> Playing 'all-circuits-busy-now.gsm' (language 'en')
    -- <SIP/100-00002401> Playing 'pls-try-call-later.gsm' (language 'en')
    -- Executing [s@macro-outisbusy:5] Congestion("SIP/100-00002401", "20") in new stack
  == Spawn extension (macro-outisbusy, s, 5) exited non-zero on 'SIP/100-00002401' in macro 'outisbusy'
  == Spawn extension (from-internal, 9015705472, 7) exited non-zero on 'SIP/100-00002401'
    -- Executing [h@from-internal:1] Macro("SIP/100-00002401", "hangupcall") in new stack
    -- Executing [s@macro-hangupcall:1] GotoIf("SIP/100-00002401", "1?endmixmoncheck") in new stack
    -- Executing [s@macro-hangupcall:9] NoOp("SIP/100-00002401", "End of MIXMON check") in new stack
    -- Executing [s@macro-hangupcall:10] GotoIf("SIP/100-00002401", "1?nomeetmemon") in new stack
    -- Executing [s@macro-hangupcall:15] NoOp("SIP/100-00002401", "MEETME_RECORDINGFILE=") in new stack
    -- Executing [s@macro-hangupcall:16] GotoIf("SIP/100-00002401", "1?noautomon") in new stack
    -- Executing [s@macro-hangupcall:18] NoOp("SIP/100-00002401", "TOUCH_MONITOR_OUTPUT=") in new stack
    -- Executing [s@macro-hangupcall:19] GotoIf("SIP/100-00002401", "1?noautomon2") in new stack
    -- Executing [s@macro-hangupcall:25] NoOp("SIP/100-00002401", "MONITOR_FILENAME=") in new stack
    -- Executing [s@macro-hangupcall:26] GotoIf("SIP/100-00002401", "1?skiprg") in new stack
    -- Goto (macro-hangupcall,s,29)
    -- Executing [s@macro-hangupcall:29] GotoIf("SIP/100-00002401", "1?skipblkvm") in new stack
    -- Goto (macro-hangupcall,s,32)
    -- Executing [s@macro-hangupcall:32] GotoIf("SIP/100-00002401", "1?theend") in new stack
    -- Executing [s@macro-hangupcall:34] Hangup("SIP/100-00002401", "") in new stack
  == Spawn extension (macro-hangupcall, s, 34) exited non-zero on 'SIP/100-00002401' in macro 'hangupcall'
  == Spawn extension (from-internal, h, 1) exited non-zero on 'SIP/100-00002401'
Re: โทรออกผ่าน GSM VoIP GW ไม่ได้
โพสต์โดย seringeti_petch » 27 มิ.ย. 2012 09:43
ถามเอง ตอบเอง ฮ่าๆๆๆ บังเอิญว่าแก้ได้แล้ว เลยเอามาแชร์ เอา Auto Call ออกนะครับ ของ IP->Tel ถ้ามันถูกเลือกไว้ โทรออกไม่ได้เลย ^^ ใน manual มันไม่ได้บอกว่ามันคืออะไร มีหน้าที่อะไร ใครรู้บ้างครับ
