ช่วยด้วยครับ TrueNetTalk โทรไม่ออก
โพสต์โดย nongkoogkai » 24 พ.ค. 2012 14:22
รบกวนด้วยน่ะครับ
-- Executing [90805888603@from-internal:1] Macro("SIP/779-0000007c", "user-callerid,SKIPTTL,") in new stack
    -- Executing [s@macro-user-callerid:1] Set("SIP/779-0000007c", "AMPUSER=779") in new stack
    -- Executing [s@macro-user-callerid:2] GotoIf("SIP/779-0000007c", "0?report") in new stack
    -- Executing [s@macro-user-callerid:3] ExecIf("SIP/779-0000007c", "1?Set(REALCALLERIDNUM=779)") in new stack
    -- Executing [s@macro-user-callerid:4] Set("SIP/779-0000007c", "AMPUSER=779") in new stack
    -- Executing [s@macro-user-callerid:5] Set("SIP/779-0000007c", "AMPUSERCIDNAME=TEST") in new stack
    -- Executing [s@macro-user-callerid:6] GotoIf("SIP/779-0000007c", "0?report") in new stack
    -- Executing [s@macro-user-callerid:7] Set("SIP/779-0000007c", "AMPUSERCID=779") in new stack
    -- Executing [s@macro-user-callerid:8] Set("SIP/779-0000007c", "CALLERID(all)="TEST" <779>") in new stack
    -- Executing [s@macro-user-callerid:9] ExecIf("SIP/779-0000007c", "0?Set(CHANNEL(language)=)") in new stack
    -- Executing [s@macro-user-callerid:10] GotoIf("SIP/779-0000007c", "1?continue") in new stack
    -- Executing [s@macro-user-callerid:19] Set("SIP/779-0000007c", "CALLERID(number)=779") in new stack
    -- Executing [s@macro-user-callerid:20] Set("SIP/779-0000007c", "CALLERID(name)=TEST") in new stack
    -- Executing [s@macro-user-callerid:21] NoOp("SIP/779-0000007c", "Using CallerID "TEST" <779>") in new stack
    -- Executing [90805888603@from-internal:2] NoOp("SIP/779-0000007c", "Calling Out Route: 9_outside") in new stack
    -- Executing [90805888603@from-internal:3] Set("SIP/779-0000007c", "MOHCLASS=default") in new stack
    -- Executing [90805888603@from-internal:4] Set("SIP/779-0000007c", "_NODEST=") in new stack
    -- Executing [90805888603@from-internal:5] Macro("SIP/779-0000007c", "record-enable,779,OUT,") in new stack
    -- Executing [s@macro-record-enable:1] GotoIf("SIP/779-0000007c", "1?check") in new stack
    -- Executing [s@macro-record-enable:4] ExecIf("SIP/779-0000007c", "0?MacroExit()") in new stack
    -- Executing [s@macro-record-enable:5] GotoIf("SIP/779-0000007c", "0?Group:OUT") in new stack
    -- Executing [s@macro-record-enable:15] GotoIf("SIP/779-0000007c", "0?IN") in new stack
    -- Executing [s@macro-record-enable:16] ExecIf("SIP/779-0000007c", "1?MacroExit()") in new stack
    -- Executing [90805888603@from-internal:6] Macro("SIP/779-0000007c", "dialout-trunk,2,0805888603,") in new stack
    -- Executing [s@macro-dialout-trunk:1] Set("SIP/779-0000007c", "DIAL_TRUNK=2") in new stack
    -- Executing [s@macro-dialout-trunk:2] GosubIf("SIP/779-0000007c", "0?sub-pincheck,s,1") in new stack
    -- Executing [s@macro-dialout-trunk:3] GotoIf("SIP/779-0000007c", "0?disabletrunk,1") in new stack
    -- Executing [s@macro-dialout-trunk:4] Set("SIP/779-0000007c", "DIAL_NUMBER=0805888603") in new stack
    -- Executing [s@macro-dialout-trunk:5] Set("SIP/779-0000007c", "DIAL_TRUNK_OPTIONS=tr") in new stack
    -- Executing [s@macro-dialout-trunk:6] Set("SIP/779-0000007c", "OUTBOUND_GROUP=OUT_2") in new stack
    -- Executing [s@macro-dialout-trunk:7] GotoIf("SIP/779-0000007c", "1?nomax") in new stack
    -- Executing [s@macro-dialout-trunk:9] GotoIf("SIP/779-0000007c", "0?skipoutcid") in new stack
    -- Executing [s@macro-dialout-trunk:10] Set("SIP/779-0000007c", "DIAL_TRUNK_OPTIONS=") in new stack
    -- Executing [s@macro-dialout-trunk:11] Macro("SIP/779-0000007c", "outbound-callerid,2") in new stack
    -- Executing [s@macro-outbound-callerid:1] ExecIf("SIP/779-0000007c", "0?Set(CALLERPRES()=)") in new stack
    -- Executing [s@macro-outbound-callerid:2] ExecIf("SIP/779-0000007c", "0?Set(REALCALLERIDNUM=779)") in new stack
    -- Executing [s@macro-outbound-callerid:3] GotoIf("SIP/779-0000007c", "1?normcid") in new stack
    -- Executing [s@macro-outbound-callerid:6] Set("SIP/779-0000007c", "USEROUTCID="TEST" <779>") in new stack
    -- Executing [s@macro-outbound-callerid:7] Set("SIP/779-0000007c", "EMERGENCYCID=") in new stack
    -- Executing [s@macro-outbound-callerid:8] Set("SIP/779-0000007c", "TRUNKOUTCID=") in new stack
    -- Executing [s@macro-outbound-callerid:9] GotoIf("SIP/779-0000007c", "1?trunkcid") in new stack
    -- Executing [s@macro-outbound-callerid:12] ExecIf("SIP/779-0000007c", "0?Set(CALLERID(all)=)") in new stack
    -- Executing [s@macro-outbound-callerid:13] ExecIf("SIP/779-0000007c", "1?Set(CALLERID(all)="TEST" <779>)") in new stack
    -- Executing [s@macro-outbound-callerid:14] ExecIf("SIP/779-0000007c", "0?Set(CALLERID(all)=)") in new stack
    -- Executing [s@macro-outbound-callerid:15] ExecIf("SIP/779-0000007c", "0?Set(CALLERPRES()=prohib_passed_screen)") in new stack
    -- Executing [s@macro-dialout-trunk:12] GosubIf("SIP/779-0000007c", "0?sub-flp-2,s,1") in new stack
    -- Executing [s@macro-dialout-trunk:13] Set("SIP/779-0000007c", "OUTNUM=0805888603") in new stack
    -- Executing [s@macro-dialout-trunk:14] Set("SIP/779-0000007c", "custom=SIP/98100003413") in new stack
    -- Executing [s@macro-dialout-trunk:15] ExecIf("SIP/779-0000007c", "0?Set(DIAL_TRUNK_OPTIONS=M(setmusic^default))") in new stack
    -- Executing [s@macro-dialout-trunk:16] Macro("SIP/779-0000007c", "dialout-trunk-predial-hook,") in new stack
    -- Executing [s@macro-dialout-trunk-predial-hook:1] MacroExit("SIP/779-0000007c", "") in new stack
    -- Executing [s@macro-dialout-trunk:17] GotoIf("SIP/779-0000007c", "0?bypass,1") in new stack
    -- Executing [s@macro-dialout-trunk:18] GotoIf("SIP/779-0000007c", "0?customtrunk") in new stack
    -- Executing [s@macro-dialout-trunk:19] Dial("SIP/779-0000007c", "SIP/98100003413/0805888603,300,") in new stack
  == Using SIP RTP TOS bits 184
  == Using SIP RTP CoS mark 5
    -- Couldn't call SIP/98100003413/0805888603
  == Everyone is busy/congested at this time (0:0/0/0)
    -- Executing [s@macro-dialout-trunk:20] NoOp("SIP/779-0000007c", "Dial failed for some reason with DIALSTATUS = CHANUNAVAIL and HANGUPCAUSE = 0") in new stack
    -- Executing [s@macro-dialout-trunk:21] Goto("SIP/779-0000007c", "s-CHANUNAVAIL,1") in new stack
    -- Goto (macro-dialout-trunk,s-CHANUNAVAIL,1)
    -- Executing [s-CHANUNAVAIL@macro-dialout-trunk:1] Set("SIP/779-0000007c", "RC=0") in new stack
    -- Executing [s-CHANUNAVAIL@macro-dialout-trunk:2] Goto("SIP/779-0000007c", "0,1") in new stack
    -- Goto (macro-dialout-trunk,0,1)
    -- Executing [0@macro-dialout-trunk:1] Goto("SIP/779-0000007c", "continue,1") in new stack
    -- Goto (macro-dialout-trunk,continue,1)
    -- Executing [continue@macro-dialout-trunk:1] GotoIf("SIP/779-0000007c", "1?noreport") in new stack
    -- Goto (macro-dialout-trunk,continue,3)
    -- Executing [continue@macro-dialout-trunk:3] NoOp("SIP/779-0000007c", "TRUNK Dial failed due to CHANUNAVAIL HANGUPCAUSE: 0 - failing through to other trunks") in new stack
    -- Executing [continue@macro-dialout-trunk:4] Set("SIP/779-0000007c", "CALLERID(number)=779") in new stack
    -- Executing [90805888603@from-internal:7] Macro("SIP/779-0000007c", "outisbusy,") in new stack
    -- Executing [s@macro-outisbusy:1] Progress("SIP/779-0000007c", "") in new stack
    -- Executing [s@macro-outisbusy:2] GotoIf("SIP/779-0000007c", "0?emergency,1") in new stack
    -- Executing [s@macro-outisbusy:3] GotoIf("SIP/779-0000007c", "0?intracompany,1") in new stack
    -- Executing [s@macro-outisbusy:4] Playback("SIP/779-0000007c", "all-circuits-busy-now&pls-try-call-later, noanswer") in new stack
    -- <SIP/779-0000007c> Playing 'all-circuits-busy-now.gsm' (language 'en')
    -- <SIP/779-0000007c> Playing 'pls-try-call-later.gsm' (language 'en')
    -- Executing [s@macro-outisbusy:5] Congestion("SIP/779-0000007c", "20") in new stack
  == Spawn extension (macro-outisbusy, s, 5) exited non-zero on 'SIP/779-0000007c' in macro 'outisbusy'
  == Spawn extension (from-internal, 90805888603, 7) exited non-zero on 'SIP/779-0000007c'
    -- Executing [h@from-internal:1] Macro("SIP/779-0000007c", "hangupcall") in new stack
    -- Executing [s@macro-hangupcall:1] GotoIf("SIP/779-0000007c", "1?endmixmoncheck") in new stack
    -- Executing [s@macro-hangupcall:9] NoOp("SIP/779-0000007c", "End of MIXMON check") in new stack
    -- Executing [s@macro-hangupcall:10] GotoIf("SIP/779-0000007c", "1?nomeetmemon") in new stack
    -- Executing [s@macro-hangupcall:15] NoOp("SIP/779-0000007c", "MEETME_RECORDINGFILE=") in new stack
    -- Executing [s@macro-hangupcall:16] GotoIf("SIP/779-0000007c", "1?noautomon") in new stack
    -- Executing [s@macro-hangupcall:18] NoOp("SIP/779-0000007c", "TOUCH_MONITOR_OUTPUT=") in new stack
    -- Executing [s@macro-hangupcall:19] GotoIf("SIP/779-0000007c", "1?noautomon2") in new stack
    -- Executing [s@macro-hangupcall:25] NoOp("SIP/779-0000007c", "MONITOR_FILENAME=") in new stack
    -- Executing [s@macro-hangupcall:26] GotoIf("SIP/779-0000007c", "1?skiprg") in new stack
    -- Goto (macro-hangupcall,s,29)
    -- Executing [s@macro-hangupcall:29] GotoIf("SIP/779-0000007c", "1?skipblkvm") in new stack
    -- Goto (macro-hangupcall,s,32)
    -- Executing [s@macro-hangupcall:32] GotoIf("SIP/779-0000007c", "1?theend") in new stack
    -- Executing [s@macro-hangupcall:34] Hangup("SIP/779-0000007c", "") in new stack
  == Spawn extension (macro-hangupcall, s, 34) exited non-zero on 'SIP/779-0000007c' in macro 'hangupcall'
  == Spawn extension (from-internal, h, 1) exited non-zero on 'SIP/779-0000007c'
    -- Remote UNIX connection
nongkoogkai
โพสต์: 53
ลงทะเบียนเมื่อ: 14 ก.พ. 2012 14:32
Re: ช่วยด้วยครับ TrueNetTalk โทรไม่ออก
โพสต์โดย nongkoogkai » 24 พ.ค. 2012 15:05
ลองลงใน 3cx โทรออกได้ และ registered ใน pbx
nongkoogkai
โพสต์: 53
โพสต์โดย nongkoogkai » 24 พ.ค. 2012 15:24
มันบอกว่า ให้ โทรใหม่ภายหลัง ครับ
nongkoogkai
โพสต์: 53
โพสต์โดย myanytime » 24 พ.ค. 2012 16:11
ผมพอรู้งูๆปลาๆนะครับ รบกวนลองทำตามนะครับ
1. เข้า putty
2. ใส่ root และ password
3. พิมพ์ asterisk -r แล้วกด enter
4. พิมพ์ sip show registry แล้วดูที่ status ครับสถานะเป็น sent หรือ register
แล้วมาบอกกันไหม่นะครับ
myanytime
โพสต์: 41
โพสต์โดย nongkoogkai » 24 พ.ค. 2012 16:21
Host dnsmgr Username Refresh State Reg.Time
61.90.255.132:5060 N 98100003413 285 Registered Thu, 24 May 2012 16:08:16
1 SIP registrations.
nongkoogkai
โพสต์: 53
โพสต์โดย nongkoogkai » 24 พ.ค. 2012 16:23
มันบอกว่า
<SIP/779-0000003c> Playing 'all-circuits-busy-now.gsm' (language 'en')
<SIP/779-0000003c> Playing 'pls-try-call-later.gsm' (language 'en')
nongkoogkai
โพสต์: 53
โพสต์โดย nongkoogkai » 24 พ.ค. 2012 16:37
ตรงนี้ต้องใส่ไหมครับ
nongkoogkai
โพสต์: 53
โพสต์โดย nongkoogkai » 24 พ.ค. 2012 16:51
มันว่างี้ครับ
nongkoogkai
โพสต์: 53
โพสต์โดย nongkoogkai » 24 พ.ค. 2012 17:54
ที่ "Dial Rules" ผมใส่ไว้ 3 บรรทัดเพื่อให้ครอบคลุมรูปแบบการส่งเบอร์ไปยัง True NetTalk
9[89]XXXXXXXXXX โทรเบอร์ True NetTalk อื่น ซึ่งมี 12 หลักขึ้นต้นด้วย 98 และ 99
555+Z. โทรเบอร์ต่างประเทศ ใส่เพิ่ม 555 ไว้ข้างหน้าเบอร์ (ตามที่ True NetTalk กำหนด)
0. โทรเบอร์ในประเทศไทย
ใส่ยังไงครับ
nongkoogkai
โพสต์: 53
โพสต์โดย nongkoogkai » 24 พ.ค. 2012 18:13
ได้แล้วครับเอา code g729 ออก
nongkoogkai
โพสต์: 53
