Setup Openfire แล้ว error
โพสต์โดย seringeti_petch » 21 พ.ค. 2012 10:12
Elastix 2.3.0 ครับ ใครเคยมั่ง ผมเซ็ตให้มันใช้ AD
HTTP ERROR 500
Problem accessing /setup/setup-admin-settings.jsp. Reason:
    Server Error
Caused by:
java.lang.NullPointerException
   at org.jivesoftware.openfire.admin.setup.setup_002dadmin_002dsettings_jsp._jspService(setup_002dadmin_002dsettings_jsp.java:99)
   at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:97)
   at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
   at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:530)
   at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1216)
   at com.opensymphony.module.sitemesh.filter.PageFilter.parsePage(PageFilter.java:118)
   at com.opensymphony.module.sitemesh.filter.PageFilter.doFilter(PageFilter.java:52)
   at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1187)
   at org.jivesoftware.util.LocaleFilter.doFilter(LocaleFilter.java:74)
   at org.jivesoftware.util.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:50)
   at org.jivesoftware.admin.PluginFilter.doFilter(PluginFilter.java:78)
   at org.jivesoftware.admin.AuthCheckFilter.doFilter(AuthCheckFilter.java:164)
   at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:425)
   at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:119)
   at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:494)
   at org.eclipse.jetty.server.session.SessionHandler.handle(SessionHandler.java:182)
   at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:933)
   at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:362)
   at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:867)
   at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117)
   at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:245)
   at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:126)
   at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:113)
   at org.eclipse.jetty.server.Server.handle(Server.java:334)
   at org.eclipse.jetty.server.HttpConnection.handleRequest(HttpConnection.java:559)
   at org.eclipse.jetty.server.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:992)
   at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:541)
   at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:203)
   at org.eclipse.jetty.server.HttpConnection.handle(HttpConnection.java:406)
   at org.eclipse.jetty.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:462)
   at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:436)
   at java.lang.Thread.run(Unknown Source)
Powered by Jetty://
Re: Setup Openfire แล้ว error
โพสต์โดย seringeti_petch » 21 พ.ค. 2012 10:56
ไม่รู้เกี่ยวรึป่าว ลอง re-start IM แล้ว setup ใหม่ ก็ได้ เฉย
แต่พอ setup plug-in Asterisk-IM ไม่ได้ มันไม่ ออนอ่ะ
