ทำไมถึงโทรไม่ออกน่ะครับ
โพสต์โดย perf62 » 06 มี.ค. 2012 21:45
Log ตอนโทรครับ ยกหูโทรแล้วมันเงียบสนิทเลยครับไม่มีเสียงพูด เบอร์ที่โทรไปก็ไม่มีสายเข้าครับ
Executing [8053700129@from-internal:1] Macro("SIP/100-0000000e", "user-callerid,SKIPTTL,") in new stack
-- Executing [s@macro-user-callerid:1] Set("SIP/100-0000000e", "AMPUSER=100") in new stack
-- Executing [s@macro-user-callerid:2] GotoIf("SIP/100-0000000e", "0?report") in new stack
-- Executing [s@macro-user-callerid:3] ExecIf("SIP/100-0000000e", "1?Set(REALCALLERIDNUM=100)") in new stack
-- Executing [s@macro-user-callerid:4] Set("SIP/100-0000000e", "AMPUSER=100") in new stack
-- Executing [s@macro-user-callerid:5] Set("SIP/100-0000000e", "AMPUSERCIDNAME=100") in new stack
-- Executing [s@macro-user-callerid:6] GotoIf("SIP/100-0000000e", "0?report") in new stack
-- Executing [s@macro-user-callerid:7] Set("SIP/100-0000000e", "AMPUSERCID=100") in new stack
-- Executing [s@macro-user-callerid:8] Set("SIP/100-0000000e", "CALLERID(all)="100" <100>") in new stack
-- Executing [s@macro-user-callerid:9] ExecIf("SIP/100-0000000e", "0?Set(CHANNEL(language)=)") in new stack
-- Executing [s@macro-user-callerid:10] GotoIf("SIP/100-0000000e", "1?continue") in new stack
-- Executing [s@macro-user-callerid:19] NoOp("SIP/100-0000000e", "Using CallerID "100" <100>") in new stack
-- Executing [8053700129@from-internal:2] Set("SIP/100-0000000e", "_NODEST=") in new stack
-- Executing [8053700129@from-internal:3] Macro("SIP/100-0000000e", "record-enable,100,OUT,") in new stack
-- Executing [s@macro-record-enable:1] GotoIf("SIP/100-0000000e", "1?check") in new stack
-- Executing [s@macro-record-enable:4] ExecIf("SIP/100-0000000e", "0?MacroExit()") in new stack
-- Executing [s@macro-record-enable:5] GotoIf("SIP/100-0000000e", "0?Group:OUT") in new stack
-- Executing [s@macro-record-enable:15] GotoIf("SIP/100-0000000e", "0?IN") in new stack
-- Executing [s@macro-record-enable:16] ExecIf("SIP/100-0000000e", "1?MacroExit()") in new stack
-- Executing [8053700129@from-internal:4] Macro("SIP/100-0000000e", "dialout-trunk,1,053700129,,") in new stack
-- Executing [s@macro-dialout-trunk:1] Set("SIP/100-0000000e", "DIAL_TRUNK=1") in new stack
-- Executing [s@macro-dialout-trunk:2] GosubIf("SIP/100-0000000e", "0?sub-pincheck,s,1") in new stack
-- Executing [s@macro-dialout-trunk:3] GotoIf("SIP/100-0000000e", "0?disabletrunk,1") in new stack
-- Executing [s@macro-dialout-trunk:4] Set("SIP/100-0000000e", "DIAL_NUMBER=053700129") in new stack
-- Executing [s@macro-dialout-trunk:5] Set("SIP/100-0000000e", "DIAL_TRUNK_OPTIONS=tr") in new stack
-- Executing [s@macro-dialout-trunk:6] Set("SIP/100-0000000e", "OUTBOUND_GROUP=OUT_1") in new stack
-- Executing [s@macro-dialout-trunk:7] GotoIf("SIP/100-0000000e", "0?nomax") in new stack
-- Executing [s@macro-dialout-trunk:8] GotoIf("SIP/100-0000000e", "0?chanfull") in new stack
-- Executing [s@macro-dialout-trunk:9] GotoIf("SIP/100-0000000e", "0?skipoutcid") in new stack
-- Executing [s@macro-dialout-trunk:10] Set("SIP/100-0000000e", "DIAL_TRUNK_OPTIONS=T") in new stack
-- Executing [s@macro-dialout-trunk:11] Macro("SIP/100-0000000e", "outbound-callerid,1") in new stack
-- Executing [s@macro-outbound-callerid:1] ExecIf("SIP/100-0000000e", "0?Set(CALLERPRES()=)") in new stack
-- Executing [s@macro-outbound-callerid:2] ExecIf("SIP/100-0000000e", "0?Set(REALCALLERIDNUM=100)") in new stack
-- Executing [s@macro-outbound-callerid:3] GotoIf("SIP/100-0000000e", "1?normcid") in new stack
-- Executing [s@macro-outbound-callerid:6] Set("SIP/100-0000000e", "USEROUTCID=") in new stack
-- Executing [s@macro-outbound-callerid:7] Set("SIP/100-0000000e", "EMERGENCYCID=") in new stack
-- Executing [s@macro-outbound-callerid:8] Set("SIP/100-0000000e", "TRUNKOUTCID=") in new stack
-- Executing [s@macro-outbound-callerid:9] GotoIf("SIP/100-0000000e", "1?trunkcid") in new stack
-- Executing [s@macro-outbound-callerid:12] ExecIf("SIP/100-0000000e", "0?Set(CALLERID(all)=)") in new stack
-- Executing [s@macro-outbound-callerid:13] ExecIf("SIP/100-0000000e", "0?Set(CALLERID(all)=)") in new stack
-- Executing [s@macro-outbound-callerid:14] ExecIf("SIP/100-0000000e", "0?Set(CALLERID(all)=)") in new stack
-- Executing [s@macro-outbound-callerid:15] ExecIf("SIP/100-0000000e", "0?Set(CALLERPRES()=prohib_passed_screen)") in new stack
-- Executing [s@macro-dialout-trunk:12] ExecIf("SIP/100-0000000e", "0?AGI(fixlocalprefix)") in new stack
-- Executing [s@macro-dialout-trunk:13] Set("SIP/100-0000000e", "OUTNUM=053700129") in new stack
-- Executing [s@macro-dialout-trunk:14] Set("SIP/100-0000000e", "custom=DAHDI/2") in new stack
-- Executing [s@macro-dialout-trunk:15] ExecIf("SIP/100-0000000e", "0?Set(DIAL_TRUNK_OPTIONS=M(setmusic^)T)") in new stack
-- Executing [s@macro-dialout-trunk:16] Macro("SIP/100-0000000e", "dialout-trunk-predial-hook,") in new stack
-- Executing [s@macro-dialout-trunk-predial-hook:1] MacroExit("SIP/100-0000000e", "") in new stack
-- Executing [s@macro-dialout-trunk:17] GotoIf("SIP/100-0000000e", "0?bypass,1") in new stack
-- Executing [s@macro-dialout-trunk:18] GotoIf("SIP/100-0000000e", "0?customtrunk") in new stack
-- Executing [s@macro-dialout-trunk:19] Dial("SIP/100-0000000e", "DAHDI/2/053700129,300,T") in new stack
-- Called 2/053700129
-- DAHDI/2-1 answered SIP/100-0000000e
ผมต้องแก้ไขยังไงหรอครับ งงมากๆเลย
การ์ด 2 ตัวครับ
perf62
โพสต์: 10
ลงทะเบียนเมื่อ: 29 ก.พ. 2012 11:54
Re: ทำไมถึงโทรไม่ออกน่ะครับ
โพสต์โดย perf62 » 06 มี.ค. 2012 21:48
เวลาที่ใช้ 5m 38s ใน Report คือผมลืมวางสายนะครับ แต่ก็ไม่มี Tone ทั้งปลายสาย ที่โทรไปหา และ ต้นทางก็ไม่มี Tone เช่นกันครับ
perf62
โพสต์: 10
