ติดตั้ง PHP 5.3
ติดตั้ง PHP 5.3
โพสต์โดย nuiz » 09 ม.ค. 2012 14:06
** ไฟล์เหล่านี้ คนทำเขาบอกว่าสำหรับ CentOS 6.2 แบบ x86_64 นะครับ **
wget 'http://www.atoomnet.net/./php/php-5.3.8/php-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.atoomnet.net/./php/php-5.3.8/php-bcmath-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.atoomnet.net/./php/php-5.3.8/php-cli-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.atoomnet.net/./php/php-5.3.8/php-common-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.atoomnet.net/./php/php-5.3.8/php-dba-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.atoomnet.net/./php/php-5.3.8/php-devel-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.atoomnet.net/./php/php-5.3.8/php-embedded-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.atoomnet.net/./php/php-5.3.8/php-enchant-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.atoomnet.net/./php/php-5.3.8/php-gd-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.atoomnet.net/./php/php-5.3.8/php-imap-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.atoomnet.net/./php/php-5.3.8/php-intl-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.atoomnet.net/./php/php-5.3.8/php-ldap-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.atoomnet.net/./php/php-5.3.8/php-mbstring-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.atoomnet.net/./php/php-5.3.8/php-mysql-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.atoomnet.net/./php/php-5.3.8/php-odbc-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.atoomnet.net/./php/php-5.3.8/php-pdo-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.atoomnet.net/./php/php-5.3.8/php-pgsql-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.atoomnet.net/./php/php-5.3.8/php-process-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.atoomnet.net/./php/php-5.3.8/php-pspell-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.atoomnet.net/./php/php-5.3.8/php-recode-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.atoomnet.net/./php/php-5.3.8/php-snmp-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.atoomnet.net/./php/php-5.3.8/php-soap-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.atoomnet.net/./php/php-5.3.8/php-tidy-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.atoomnet.net/./php/php-5.3.8/php-xml-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.atoomnet.net/./php/php-5.3.8/php-xmlrpc-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.atoomnet.net/./php/php-5.3.8/php-zts-5.3.8-1.el6.x86_64.rpm'
หรือจะดาวน์โหลดจากเว็บนี้ก็ได้
wget 'http://www.voip4share.com/sources/php-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.voip4share.com/sources/php-bcmath-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.voip4share.com/sources/php-cli-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.voip4share.com/sources/php-common-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.voip4share.com/sources/php-dba-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.voip4share.com/sources/php-devel-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.voip4share.com/sources/php-embedded-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.voip4share.com/sources/php-enchant-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.voip4share.com/sources/php-gd-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.voip4share.com/sources/php-imap-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.voip4share.com/sources/php-intl-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.voip4share.com/sources/php-ldap-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.voip4share.com/sources/php-mbstring-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.voip4share.com/sources/php-mysql-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.voip4share.com/sources/php-odbc-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.voip4share.com/sources/php-pdo-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.voip4share.com/sources/php-pgsql-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.voip4share.com/sources/php-process-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.voip4share.com/sources/php-pspell-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.voip4share.com/sources/php-recode-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.voip4share.com/sources/php-snmp-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.voip4share.com/sources/php-soap-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.voip4share.com/sources/php-tidy-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.voip4share.com/sources/php-xml-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.voip4share.com/sources/php-xmlrpc-5.3.8-1.el6.x86_64.rpm'
wget 'http://www.voip4share.com/sources/php-zts-5.3.8-1.el6.x86_64.rpm'
