ผมจะโทรผ่านTOTnetcall แล้วไม่ติดอะครับมันขึ้นแบบนี้อะครับ
โพสต์โดย pikezeed1 » 08 ธ.ค. 2011 11:08
Using SIP RTP TOS bits 184
== Using SIP RTP CoS mark 5
-- Called TOTnetcall/0899665893
-- SIP/TOTnetcall-0000000d is circuit-busy
== Everyone is busy/congested at this time (1:0/1/0)
-- Executing [s@macro-dialout-trunk:20] NoOp("SIP/1002-0000000c", "Dial failed for some reason with DIALSTATUS = CONGESTION and HANGUPCAUSE = 21") in new stack
-- Executing [s@macro-dialout-trunk:21] Goto("SIP/1002-0000000c", "s-CONGESTION,1") in new stack
-- Goto (macro-dialout-trunk,s-CONGESTION,1)
-- Executing [s-CONGESTION@macro-dialout-trunk:1] Set("SIP/1002-0000000c", "RC=21") in new stack
-- Executing [s-CONGESTION@macro-dialout-trunk:2] Goto("SIP/1002-0000000c", "21,1") in new stack
-- Goto (macro-dialout-trunk,21,1)
-- Executing [21@macro-dialout-trunk:1] Goto("SIP/1002-0000000c", "continue,1") in new stack
-- Goto (macro-dialout-trunk,continue,1)
-- Executing [continue@macro-dialout-trunk:1] GotoIf("SIP/1002-0000000c", "1?noreport") in new stack
-- Goto (macro-dialout-trunk,continue,3)
-- Executing [continue@macro-dialout-trunk:3] NoOp("SIP/1002-0000000c", "TRUNK Dial failed due to CONGESTION HANGUPCAUSE: 21 - failing through to other trunks") in new stack
-- Executing [continue@macro-dialout-trunk:4] Set("SIP/1002-0000000c", "CALLERID(number)=1002") in new stack
-- Executing [770899665893@from-internal:5] Macro("SIP/1002-0000000c", "outisbusy,") in new stack
-- Executing [s@macro-outisbusy:1] Progress("SIP/1002-0000000c", "") in new stack
-- Executing [s@macro-outisbusy:2] GotoIf("SIP/1002-0000000c", "0?emergency,1") in new stack
-- Executing [s@macro-outisbusy:3] GotoIf("SIP/1002-0000000c", "0?intracompany,1") in new stack
-- Executing [s@macro-outisbusy:4] Playback("SIP/1002-0000000c", "all-circuits-busy-now&pls-try-call-later, noanswer") in new stack
-- <SIP/1002-0000000c> Playing 'all-circuits-busy-now.gsm' (language 'en')
-- <SIP/1002-0000000c> Playing 'pls-try-call-later.gsm' (language 'en')
-- Executing [s@macro-outisbusy:5] Congestion("SIP/1002-0000000c", "20") in new stack
== Spawn extension (macro-outisbusy, s, 5) exited non-zero on 'SIP/1002-0000000c' in macro 'outisbusy'
== Spawn extension (from-internal, 770899665893, 5) exited non-zero on 'SIP/1002-0000000c'
-- Executing [h@from-internal:1] Macro("SIP/1002-0000000c", "hangupcall") in new stack
-- Executing [s@macro-hangupcall:1] GotoIf("SIP/1002-0000000c", "1?noautomon") in new stack
-- Executing [s@macro-hangupcall:3] NoOp("SIP/1002-0000000c", "TOUCH_MONITOR_OUTPUT=") in new stack
-- Executing [s@macro-hangupcall:4] GotoIf("SIP/1002-0000000c", "1?skiprg") in new stack
-- Executing [s@macro-hangupcall:7] GotoIf("SIP/1002-0000000c", "1?skipblkvm") in new stack
-- Executing [s@macro-hangupcall:10] GotoIf("SIP/1002-0000000c", "1?theend") in new stack
-- Executing [s@macro-hangupcall:12] Hangup("SIP/1002-0000000c", "") in new stack
== Spawn extension (macro-hangupcall, s, 12) exited non-zero on 'SIP/1002-0000000c' in macro 'hangupcall'
== Spawn extension (from-internal, h, 1) exited non-zero on 'SIP/1002-0000000c'
พอดีทำโปรเจ๊คจบอะครับ พึ่งหัดทำ ผิดพลาดอะไร ชี้แนะทีนะครับ
pikezeed1
โพสต์: 7
ลงทะเบียนเมื่อ: 02 ธ.ค. 2011 00:03
Re: ผมจะโทรผ่านTOTnetcall แล้วไม่ติดอะครับมันขึ้นแบบนี้อะครับ
โพสต์โดย nuiz » 08 ธ.ค. 2011 15:44
จากข้อความนี้
แสดงว่าโทรไม่ได้ ทางฝั่ง totnetcall รีเจ็คกลับมา
เช็คว่ารีจิสเตอร์ได้ยัง คำสั่ง sip show registry
แล้วก็เช็คว่าคอนฟิก trunk ถูกหมดป่าว มีตัวอย่างบอกไว้อยู่ครับ ลองหาจากกระทู้แรกๆดู
ถ้าเช็คจนชัวร์ว่าถูกหมดแล้ว ไม่มีไรผิด แต่ยังโทรไม่ออก ให้ลองโทรหลายๆครั้งครับ บางทีมันโทรยาก
โพสต์โดย pikezeed1 » 08 ธ.ค. 2011 20:43
ขอบคุณมากครับคุณพี่ nuiz
Registry ติดแล้ว
ผมจะลองเช็ค ส่วนของ Trunk อีกทีครับ
ขอบคุณอีกครั้งช่วยผมได้มากจริงๆ^^
pikezeed1
โพสต์: 7
